I have a number of brand new latest rev. L B&O 200ASC IcePower modules and would like to sell most of them.
Click for Data Sheet
- 200 Watts @ 4 Ohm
- Built in universal switch mode power supply
- +/- 12V aux supply for x-overs or EQ
- LED indicator drivers
- Auto or manual on/off
- easy to hook up
- fully protected
Do You know if the power supply on these will play well with the Icepower 250A modules?
thanks,
charlie
thanks,
charlie
I do not know. I believe the 200 ASC supplies +57V. Click on the data sheet links and you will find the data sheet for the 200ASC. The sheet for the 250 is also on same web B&O site. I would suggest referring to the data sheets to be sure of a correct answer.
The 47V PSU should be fine, but the +/-12V PSU on the 200ASC is a bit underpowered for anything more than a single 250A (check the current consumption in the data sheet). If you can find the 200AC module, connecting two of those to a single 200ASC is not a problem.
/U.
/U.
I still have plenty of these available. PM me if you want any. If the price does not look right, let me know. I have some room to negotiate depending on quantities and terms.
