My goodness! You absolutely had to see to believe this monstrosity. I saw and touched this thing in person at a local 12v amp repair shop here in Atlanta.
Yes thats a measley dollar bill sitting on top of it. The value of this amp is anywhere from $1000 to $4000. Its about 2 x 3 feet x 6 inches in absolute girth and takes two people to lift.
its supposedly 'rated' to 6000 x 1, but the repair guy said it is likely closer to about 15,000w. The transformer is the size of a small pizza, and there were so many transistors inside that I lost count after about 75.
Unfortunately I wasnt able to grab this sucker; its brain guts and protection circuit needed repair. and the repair guy was still having "at it". I'll probably try and get it next time as he felt like not wanting to spend his days figuring it out. Bummer!
Happy drooling!
Happy drooling!
That's totally not necessary. I don't even want to know what the subs looked like that would handle 15kW. Unless that was an amp for the front stage 😛
(Not my picture, but kinda funny)
Sub? Try like a dozen subs. And I agree. I'm very happy with my measly 400w running to my single 10".
Evening Dr. Zeus, looks like you found your Jiggawatts amp 🙂
I actually know someone that won one of these as a door price at a gear show some years back when they were new on the seen. He sold as I recall😀
I would have hung it on a wall somewhere myself. Somethings just are either too big or too once in a lifetime to actually put into use. For me this one of those things.
It would make a nice hanging ornament in a amp repair shop. maybe with a sign hanging over it saying something like "and your worried about your repair bill"...lol lol lol...😀
seen the internal pics in ampguts. the parts are massive. more at home in a power plant or something.
I could deal with having the power but its totally impractical size wise and would get very tiring to see in the car all the time, lol. It would basically demand everyone's attention, kind of like always saying "look at me... look at me"
that would take care of all the people who think under powering kills
HAHAHA!
Amps don't blow speakers.... I do.
not to mention the amount of CURRENT this bad Mofo needs to run! call it the alternator killer! this thing can suck down a battery like sucking the juice out of a grape! that alternator will overheat in a matter of minutes trying to keep up! you would have to have multiple batteries and a dedicated charging system just to run this dang thing!
cool amp, but am not sure about 15k, but it sure does look massive
This amp has a 600A slow-blow fuse, making it possible to hit probably 1000A for a bit of an instant. At that level your looking at ~14000w. Looking at the amp's ratings makes you just wonder...
6000w RMS at 4 ohms
6000w RMS at 2 ohms
6000w RMS at 1 ohm
Its 'rated' not to double when the load is halved I dont see why it would be stuck at 6000w every time. I forget what kind of monster cable was required to wire this beast up.
Surely this amp was never designed to be in a car. You'd need a string of deep-cycle 12v batteries to keep it pressing out the wattage.
What do the ~7-10k Cactus amps have on this?
If the amp is designed to produce 6kw into any load, it's entirely possible to make it do just that. Look at the JL slash series amps. They do the same power throughout their entire range of acceptable speaker loads.
I could be wrong but I believe they were mainly designed for competition systems. There's a photo on the net somewhere that has what appears to be at least 8 of them installed.
as far as I know, this amp as some other JBL (crown) can be high voltage or high current, that is why it is rated at 6k from 4 to 1R loads... since it is rated 6k at 4R, it has to have very high voltage, that would in 1R sag a lot, but still make HUGE amount of power, but components inside are not raded for such power (current in that 1r load)This amp has a 600A slow-blow fuse, making it possible to hit probably 1000A for a bit of an instant. At that level your looking at ~14000w. Looking at the amp's ratings makes you just wonder...
6000w RMS at 4 ohms
6000w RMS at 2 ohms
6000w RMS at 1 ohm
and yes it was designs for car and only car, just big on power... but uses same tech as do their PA amps, mains powered.
There are a lot of high and even alot higher power amps out there, but none of them are as good for 4R as are for 1R loads, most have "0.5" of the power, if load is 2x higher
pictures
http://ampguts.com/gallery/showphoto.php?photo=3601&nojs=1
this amp is good, coz even with impedance raise in box, you can still deliver a lot of clean power
I was wondering if someone could recommend a place to get this repaired at. Or help me trouble shoot it. Sorry for the language in the video. YouTube - Update On JBL Crown a6000gti (8000 Watt Amp)
- General Interest
- Car Audio
- JBL 'Crown' A6000GTi - Thats a HUGE b*
