DocLorren said:Or, eh ...use the dock? It's output is plenty for a stereo receiver line-in.
Be careful with mentioning this.
DocLorren said:you were SOOO confusing.
Hmm, I took great care to deliver explanations to every term I used, proove my measurements with pictures, support my results with mathematical background, give links to read up - and answer questions as they came...
I think the main problem is that the thread starter confused peak voltage, average voltage, and level. And then didn't manage to read thoroughly...
As of my perception, someone with the plan to actually build a variable gain stage circuit should be aware of certain important basics. If some terms are new to the reader - or some explanations sound too long to follow easily - I would consider it a good opportunity (and a good point in time) to gain the knowledge that will definitely required down the course of this project anyway.
actually, im quite very familiar with those concepts. what i asked, if you'd read my posts, was what was the RMS output of the 1/8 stereo out of an ipod. i said if you only knew the peak i could convert to RMS.
oh yeah, and i already built two circuits that boost the ipod to stereo line level. so, sek, i HAVE actually built a variable gain stage circuit before even starting this thread. so, don't assume because someone asks what you perceive as a dumb question that the person asking it is dumb also.
as i said earlier, i was hoping people would share their designs for ipod/stereo interfacing. thank you.
gain said:don't assume because someone asks what you perceive as a dumb question that the person asking it is dumb also
I honestly didn't do so, fellow DIYer. It just ceases to amaze me how many repetitions needed to occur in this thread (question clearance, device determination, number games, etc.). I claimed this to be rooted in your constantly changing your mind and your not reading thoroughly. Dumbness is (and was) not my assumption! That's all.
As I said, I doubt this. First you confused voltages (Vrms, Vpeak) with each other and with the term level. Then you couldn't handle the unit conversion (and the unit decibels), which you actually should be familiar with from your former builds. All I want to do is to be of help, really.
Yes, but for whatever reasons, you need help on a new one.
Now that we mention it, what's the deal with your other gain stages? Why aren't they suitable to your needs?
Of what we heard so far, what you need is a single supply line stage with trimmable gain (i.e. a trimmer as gain resistor). Add a potentiometer in front of it and you're all set. This tutorial gives all the details, it even contains a calculation example of a stage with gain of +10, which is exactly what you need. As an opamp I recommend Texas Instrument's OPAx353 or any other single supply opamp.
Here's some literature: Designing Gain and Offset in Thirty Seconds and the Op Amps for Everyone Design Guide (Rev. B), both by Texas Instruments. The latter will show in every detail how to use even ultra precison opamps in a single supply application.
Maybe you can't find any project (and don't get any feedback on your question) because your problem is too specific. Instead, take a look into any headphone preamplifier project intended for battery use. They show how to generate an opamp supply out of 12V (or the like) and connect quality opamps. Google knows how to find DIY headphone projects, first hit is the good old CMOY (of which figure 2 is your desired circuit and figure A2 the solution to your problem).
i never even attempted these conversions.
i asked for people to share circuits that they had had success with in the past. this is hardly a cry for help, imo.
never said they wern't. my op was a question about RMS output from ipods.
that is great info. thank you.
im kidding with you, Andrew!
don't you know i started this thread secretly knowing it would amuse you?
jk ... respect to you Andrew. this thread feels like when you ask one of those simple questions and the someone who answers must feel the need to complicate the issue so profusely in order to make themselves and what they do sound more important than they really are. its a self esteem issue mostly, sometimes comical to watch.
oh yeah, something else i thought i'd share because no one mentioned it to me.
you don't need a gain stage to plug an ipod into a stereo line in. just a cord with a 1/8 stereo male on one end and two RCA males on the other. connect them together, crank the ipod to the max, and the input level is very close (a little less) than what the stereo is expecting but not by much. you will still hear the ipod just fine. the gain stage just gives the signal a little more 'oomph', but again, not necessary to enjoy your ipod through your stereo.
peace.
peace.
To whom it may concern,
making a fool of me is totally uncalled for, 'dude'!
And now turning the story backwards and claiming you knew everything and actually asked for nothing is just ridiculous, honestly!
As Andrew subliminally mentions, someone special really needs to reread this thread, but it certainly won't be me!
You're just odd, 'dude'!
some cell phones when you plug them into usb will 'become' another hard drive. find the right folder the mp3's are in, then drop your files in there. bingo, instant cellular-mp3 player! making sure the mp3 tags are correct will greatly aid your device search for individual titles / artists.
sek said:To whom it may concern,
making a fool out of you was not my intentions. pointing out the erroneous statements you made was. i feel bad if i offended you. besides, YOU are the only person who can give someone permission to make a fool of yourself
go back and reread my original post. it was a question asked, not a claim of omnipotence.
why not? if you have some sort of problem with me be a man (or woman or whatever you are) and take it up with me yourself. if sure you can figure out how to PM if you are as knowledgeable as you claim.
now, i will try again. would anyone like to share stories or diagrams for interfacing ipods to home receivers?
i made two, one based on an opamp and the other built on a single transistor amp. opamp one sounds nice, single tranny one sounds, well, not audiophile quality.
thank you.
thank you.
Instead of going to Kindergarden again, I'll just make a couple of quotations, highlighting some areas in order to support my point.
Here the problem begins with some general misconception about the relation between an electrical change and the corresponding audible change in level:
The trouble is that it leads to some guesswork which, while looking educated, is in fact way off:
Here's some proof of my claim about general lack of understanding:
The main misconceptions here are that turning the knob in hifi gear will lead to some standardized or proportional behaviour and that - on top of that - this could possibly be related to perceivable absolute values (see "Psychoacoustics: Facts and Models").Post #13
i have the ipod hooked to a line level input on a receiver im listening to now, ipod cranked to about 4/5, stereo on about 4, and it sounds (subjectively, to me) to be about the same input level as cd
The error between guessed and measured value is the same magnitude as the error between guessed and anticipated value (for a link to a unit calculator between voltages and levels see my post #28 above).Post #17
so i guess that ipod puts out somewhere 1/2 line level (ie: ~500mv RMS)
Post #22
i don't know what all this Urms, VP, LP, etc means.Neither were the units I used quoted in context. Nor is the difference between the terms RMS and level ever getting appreciated (my post #28 also contains links to wikipedia regarding the terms used).[...]
all audio amps have peak voltages they are capable of delivering to the load. it is usually measured in +/- Volts RMS.
can anyone here answer what the max RMS voltage output of an ipod is or do i have to drive 45min to a lab with a scope and measure myself.
Here's the not reading thoroughly. Note that I explicitly prevent blaming anyone for lack of knowledge. It's okay to ask questions, it's just not okay to reject answers for being too complicated...
It's okay to not understand something, remember it could also have been me who didn't make it clear. But blaming others and making false claims is just odd. Let's just note that I didn't suggest anything like the above...Post #25
i dont know what anything sek is saying. i don't even own a scope, let alone sophisticated computer measuring equip like he suggests using.
And how about some arrogance starting to chime in? Here you are:
Remember this was just after I offered my help and had promised to measure.Post #27
i'll go measure, experiment and speak with other experts. i'll also give up hope of getting a straight answer on this thread.
It could have been over at this point. But sadly... well, in case this was funny so far, wait until the first signs of self-contradiction appear:
Familiarity with a concept is more than having heard the words before. Also, a reference to the first post is being made, completely ignoring other questions asked thereafter. And for the record, the claim "i said if you only knew the peak i could convert to RMS" is just plainly untrue.Post #45
And now - drum roll - the moment where the thread starter bursts the limit:
If this doesn't pose the thread ad absurdum, then what does? Besides that this is simply what you try first before you consider building a dedicated circuit for it, if the possibility was unclear before then why not simply ask? If the abilities of the purchased gear were unclear, why not just read the manufacturer's recommendations? It's all in the support documents, i.e. the features guide on pp. 26, 37, 53, 65. Could have saved everyone a lot of trouble...Post #50
In the light of all of this, I don't think i really have to follow up on expressions like these any longer:
This forum doesn't support PMs. Go figure. Now how much more than chickening out is this void offer?Post #56
All in all, this thread certainly won't serve as a source of other's project recommendations any more. It just can't, whom would one expect to give away his/her knowledge in the light of such a struggle.
@gain: I recommend you to open up another thread regarding project questions. Don't expect anyone to take part in a discussion with you, after you've proven so badly what someone willing to help you would have to expect from you.
Now, what makes me feel you'll be tempted to blame someone else for this thread going downhill (again)?
gain said:you're cool. we misunderstood each other. peace?
I don't believe you just give in, I believe you consider yourself the smarter one. Right?
Kidding!
Peace!
gain said:you can PM on the forum. the person you PM gets an email.
You could. But this requires the receiving user to activate this option in the user's profile. And you didn't.
PS: Honestly, you should open up another thread. If only for posting a better suited thread title for the browse and search pages. And I promise to not throw any more unwanted measurements on you.
- Digital Line Level
- anyone know the RMS output of an ipod?
