Good morning,
I have a CD-73, the cleaning, I removed the bullet SONY CX7935, which is located next to the CX7933!
There is no coding, can you tell me which way the hand?
Bests regards
Fred
http://apu.mabul.org/up/apu/2008/06/09/img-164724arngw.jpg.html
Bests regards
Fred
fred78 said:Good morning,
Bests regards
Fred
Salut!
Look at post #509
http://www.diyaudio.com/forums/showthread.php?s=&postid=1461559#post1461559
Salut,
Un Portugais, ça parle francais ...
En fait, je ne sais pas exactement où va la puce SONY CX7935 sur le Circuit imprimé !!!
L'ancien proprietaire a demonte la platine, et j'ai un doute !!!
Sinon, le defaut constate est le suivant:
La platine demarre, s'arrete, repart pour s'arreter, comme ci le moteur manquait de courant !
Ce n'est pas le bloc CDM1, je l'ai internvertit avec mon autre CD-73, ce n'est pas non plus la carte d'alimentation ...
Si tu as une idée, je suis preneur.
Fred
Fred
Hi Fred,
This is an English speaking forum. If you wish to post in another language please also post in English.
Thank you.
Thank you.
Hi Fred
Have you see the picture at the link I gave to you, in post #2 ?
There you can see a picture of the SONY CX7935 IC with the correct orientation... 😉
Bon soir!
Good Jorge,
Yes, I saw the photo, but it was not clear!
The CX7935 is well down the left with the tip of foam above?
Best regards.
Fred
PS: Sorry for the language Cal !!!
Best regards.
Fred
This thread could be also of interest in this case:
http://www.diyaudio.com/forums/showthread.php?p=1940336&posted=1#post1940336
- Digital Source
- Sony CX7935 in Marantz CD-73
