Banned
Joined 2002
jleaman said:What is the rail voltage?
Whatever you set it to be within the limits of the part.
jleaman said:How much current can be draw at a constant?
That depends on which part you use. The LM338 is rated for 5A continuous with adequate heatsinking.
Yes, but input-output voltage differential must be 10 volts, or lower.
Maximum recomended dissipation is 50W.
Yes, it has provision for snubber RC component as suggested by carlos.redrabbit said:Snubberized?
Output voltage and current depends on component you use. Please check datasheet of LM338 or LT1083.jleaman said:What is the rail voltage ? How much current can be draw at a constant ?
jleaman said:
Are you going to get some boards made ?
Yes, I am going to make two 70 micron boards for myself. If someone is interested, I can order for them too. You only pay the charges at actual.
Attached is updated layout with provision of LT1083.
Please provide feedback and any inputs for improving it.
Yusuf
- Power Supplies
- PCB: LM338 Regulated Snubberized PSU
