Cal Weldon said:I'm feeling pretty horny myself.
Think I'll go crank up the A4's
Cal
Show off!
Coolin said:bzdang , what kind of woofer is that? it looks like a small trashcan lid Passive radiator?
Hah, It's a Lab12 that someone spray-painted silver for Lord-knows-what-reason. Just in a sealed box that I had lying around.
bzdang said:Yes, it would be perhaps more useful than the high-efficiency section of AA
Well, yes _grin_
regards
Ken L
bzdang said:
Hey bz, Since I cannot send you PM (you haven't enabled it) I just wanted to tell you that I have and use the tool room lathe in your avatar. Great beast!
Puzzled, I checked my settings and pm is enabled, although I've not ever received any. You have my email address somewhere, we were discussing telescope shelters. BTW, I met with Randy this week and he does know your friend Bill.
Closer to topic, I have a 9 inch workshop lathe in RCAF blue, which I used to make some parts for the hornguy to mount a D175 on his lovely cast aluminum horn [talk about DIY!]. He's off to Oswald's Mill with it this weekend. Here's a photo.
bz,
Look at the bottom of your post frame. It says [WWW]. If pm is enabled it would say .
Oh yeah, I 'member. Great memory just overloaded.
That is a fine looking aluminum conical horn. What was it originally a microwave antenna?
My Southbend is the big one with 16" swing and 36" bed. I have a 3 and 4 jaw chucks, steady rest and complete collett system but haven't ever used colletts.
I like turning good aluminum alloys. Easy to machine and polish oh so nicely. I just turned a pair of 400 Hz front horns in mine out of solid Black Walnut.
Since we're on about horns here, this is a picture of my just completed walnut 400 Hz front horns. The component being turned in the lathe picture of the previous post is the adapter ring that mounts a 4" driver to the throat at the back of the horn. It is the last step section seen in this photo (left horn) held on with 1/4-20 brass screws.
- why no seperate horn forums
