What would be the best amp to use in a tri-amp setup, in your opinion? This would be for tweeters only. Approx. 10-20W power. I tend to prefer class A designs with little or no global NFB. I considered an Aleph, but their high frequency performance seems to be lacking compared to their midrange performance. What about a JLH? No chip amps, please.
To have no negative feedback in a SS amp, one would have to be pretty precise when matching transisors, resistors and other componants. 10-20W of power can be done without that many components. You could design it yourself, then you would have total credit for it in the DIY spirit . No one says you can't use the basic topologies of others' designs, then you can use quality parts that are availible cheaply in your area. You need to have a good knowlege of electronics to make one completly from scratch though.
I use and like and would recommend JLH simple class A type amps - one of the later versions...
http://www.tcaas.btinternet.co.uk/jlhupdate.htm
but it does have global feedback but does not seem to suffer from the "solid state / feedback" sound
If you implement it with care and choose good components it could sound great.
but perhaps you should check out this thread as well
http://www.diyaudio.com/forums/showthread.php?s=&threadid=42259
there are some interesting design ideas discussed here. The design that AKSA mentions sound very interesting to me and could suit your reqirements.
mike
mike
I would go for the JLH class a amplifier, or the DOZ
amp from rod elliot. They are both fantastic amps for low
power applications, specially for mids and tweeters.
sound.westhost.com
sound.westhost.com
I also cast my vote for the JLH design (or Rod Elliots version). Having been a tube lover for 30 or so years, I now no longer recommend them. As good quality tubes and transformers get more and more scarce, the price has gone up way beyond reason for what you get. I finally swapped out my tubes for the later JLH flavor, finding that I had all of the sweetness and purity I liked with tubes, plus gained better bass and treble extension, all with the stability of solid state.
- best tweeter amp?
