garbage said:I was under the impression that a PSU with higher VA should help since the power supply caps used in a Gainclone is generally 1000uf or so.
Was thinking of getting the highest VA I can find with dual 18V secondaries for an future Gainclone project.
Really, there is no need to go to extremes in transformer VA ratings. I don't believe that it will make much of a difference. The only effect it would have is increasing the amount of current the amplifier can draw from the transformer's secondaries without overloading the transformer. Since a stereo gainclone draws very little current, this should be of little concern. I'm not sure if I understand what you meant about a transformer with a higher VA rating would help because of the low values of the filtering caps typically used. Increasing the current handling of a transformer will not make any difference here, unless the amp is current-starved to begin with, which will cause voltage sags. You can naturally use larger filtering caps if you so desire, but it would not be necessary.
As a general rule of thumb, I like to have a transformer that can supply about 25% more current than the amplifier should draw, just to have an extra safety margin, and to prevent it from getting hot. For a typically stereo gainclone, anything over 300VA would really be a waste money (unless you just happen to have one on hand or find a really good deal on one some place). I would certainly recommend a quality transformer, though, not just going after the cheapest you can find. However, I suggest spending more money on high-quality components, or maybe even a more elaborate CLC filtered and/or regulated power supply. In which case, you would need to slightly increase the voltage and the current capacity of the transformer to account for the innefficiencies involved.
1000 uf??? not at all true. some people who want no bass responce will use 1000uf. if you want a full range amp you should use something more like 5000uf on each rail. i think the more capacitance the less VA you need for the same power since between boom sounds the caps have time to recharge.
I am using BrianGT GC-Kit which comes with 1000uf cap and the little amp provide all the bass I ever need. I like "No women no cry" too.
Regards,
Chris
- Chip Amps
- More VA the merrier?
