My brother and a friend used to get high and tinker and they concluded that if you glue toothpicks on a floppy cone in a spiral pattern (much like you see on headphone diaphragms) you can get a smoother sound. The only test equipment they had was their "augmented" ears, so.... the inverse of the idea appears to also work well...
He's referring to glue on PP cones, which can definitely have a measurable positive effect.MisterTwister said:Actually applying damping material without cone slicing has an insignificant effect on cone breakup. Aluminum cones would be hardly damped at all, even when thick layer of spray is used.
I have no experience regarding metal cones but my Vifa P21 got better with silicone strings, however it did not take away the break up of the cone completely.
I have no measurments to confirm it, so take it for what it is. Purely subjective opinion.
They may been better with slicing but not reversible. In the end I realized I was trying to use them too high in frequency with beaming and so on.. It was easy to take away the silicone anyway.
I will try slicing on cheaper woofers when funds permits an ob speaker project.
You have a real nice result with your experiments and backed up with measurments. Good work!
Regards,
Peter
- ScanSpeak-style cone slicing
