Is this a gainclone?
Hi!
Can any1 tell me if this can be considered a gainclone?
It's a LM12.
Sorry about the pics...
I have a Mustek camera and the minimum focus distance is 60cm...
Pedro Martins
It's a LM12.
Don't see why not. Hell, it looks like my amp! Well, without the chassis. :)
I don't even have that. I have to settle for line drawings.
Mine is the same basic configuration done on a similar heatsink, with a wood chassis around it, a wooden back and a trim strip between the fins down the middle.
se
cheers bud!
yes its not quite as good as the other chips with 80watts, but if you only need 80watts its good. plus look at the package it comes in, To3, with only 4 pins, that eases up a lot on pcb design and space, plus it will mount in the heat sinks i reclaimed from a load of mosfet amps, i got 8 large (150watt dispersion) sinks that it'll fit stait into. once again, cheers bud. :) steve.. ..
