Originally, in Aleph AX, Nelson was using 4 paralleled CL-60 thermistors between capacitors banks (instead of chockes) for PS filtering. I also use those thermistors for filtering and they work pretty well providing additional inrush protection as well. The alternative would be using 0.3-0.5 power resistors instead of chokes or thermistors.
I thought I'd read somewhere that there were some problems with the Thermistor trick as a CRC and here is the link to support is by the One and Only himself:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=8882&highlight=thermistor
Nobody ever reallysolved this althought possible solutions are mentioned
Ralph
Ralph
Peter Daniel said:They run so hot, that you can't touch them. As to the leads diameter and handling inrush currents, I think that they are still bigger gauge than the fuse element.
Point taken, but I do not use fuses after the AC Mains, then it's a ThermoMagnetic Breaker.
Anthony
CL-60 in an AB amp
So...
What about using a CL-60 on the AC side in a Class AB amp?
I have big caps, 61mF - okay, not that big, but big enough I need some inrush protection and I don't want to be bothered with the whole relay delay thing. I'm making a quick 'n' dirty amp.
I figure the caps are big enough to handle the peak draw from the amp, and the only downside could be the additional resistance of the CL-60 when the amp is at idle or low power. Which shouldn't be a problem because the caps are big.
The amp's an ESP P3A, 48VCT transformer, about 34V rails, maybe 80W/ch into 4 ohms.
Thanks for your thoughts...
So...
Re: CL-60 in an AB amp
It all depends on how much current the amp draws when idle. With little current you may find that voltage drop on thermistor is too big. For comparison, with Alephs it's less than 0.5V.
paulb said:So...
Peter Daniel said:I don't use fuses on secondaries either, and here few thermistors are used in parallel to avoid current limiting. By comparing them to fuses, I only had in mind the primary circuit.
Hey Peter I am trying to find a source for these inductors, they look interesting.
http://www.schottcorp.com/products/...y&cat_id=124&highlight=1&product_number=35070
Anthony
Peter Daniel said:They look interesting. What about ordering samples?
Already did, hope to hear from them soon. Digikey has some of thier product for $10 CAD. They do not have the values we would want. I am going to call them tomorrow for an RFQ.
Anthony
- Cl-60
