Virtual Tek 576/577 curve tracer in EWB V10
After hectoring EWB around the walls of Troy, National Instruments relented and incorporated a new virtual instrument in Electronics Workbench V10 -- a virtual curve tracer -- i had been doing this with the piecewise voltage function and virtual scope. should make it much easier to compare home-brewed models of transistors etc. Looks like you can test diodes, bjt and MOSFETs.
The new EWB also allows you to select more footprints for physical components.
