Hello,
Is it bad to use pre-meade, cheap computer speakers as cabinets for better speakers? I want to make a decent quality 4.1 system, but size is just as important as sound for this purpose. I can get a set of the Creative Inspire 4.1 4400 speakers, http://www.creative.com/products/product.asp?category=4&subcategory=26&product=446
pretty cheaply, and they are a good size and color for my application. The satellites are plastic and the subwoofer is MDF with a port hole. If I were to replace the drivers with higher quality speakers like tang bands and use a better amp, would the overall sound suffer signifantly or would I still be able to get a decent sound out of them. Keep in mind that my ears are nowhere near "golden", my room probably has terrible acoustics, and there is a lot of noise pollution in the area, so I don't need a perfect system, just a good one.
Also, if the creative ones are bad to modify, but a different set at around the same cost works well, please mention it.
Thanks,
Robert
Thanks,
Robert
Replacing the drivers in existing speakers with better drivers will give better sound. It's really a matter of how much better you want. It looks like these are small speakers and that you're looking at replacing the drivers with fullrange units?
There are a lot of inexpensive full/wide range drivers out there - TB and Hi Vi to name a few. You will need to consider resistance and sensitivity to match with your amp, and yes a better amp is a good idea too.
I'm not sure you should buy a brand new set of speakers, regardless of price/quality, only to gut them and replace the drivers, unless their particular look is important to you. You might consider shopping for a used set on eBay - tons of compact/computer speakers available there. You might consider bookshelf/surround cabinets if you want to build a little bigger/better.
If you're feeling a little more ambitious and would consider building from scratch, you might ltake a look at these projects by a very well respected designer:
http://www.zaphaudio.com/audio-speaker18.html
http://www.zaphaudio.com/audio-speaker20a.html
Thanks for the reply,
I plan on buying a used/broken set since the actual workings of the original components don't really matter. I want to build my own cabinets, but although I am pretty handy with tools, I don't have access to them. Also, the price factor is significant too. These speakers cost about $50 new, so I should be able to find a used set very cheap.
Robert
Robert
