Are there any particular resistors to avoid in passive crossovers? Wirewound cement resistors seem suitable to me but I am worried abut the inductance associated with them. Are their inductance significantly high?
Any other concerns about resistor selection?
Thanks,
Murat
Thanks,
Murat
Why not play it safe and use metal oxide resistors? They're only a dollar each at madisound. Worth the piece of mind....
javascript:smilie('
angel
www.gattiweb.com
javascript:smilie('
angel
www.gattiweb.com
The other thing is that most wirewound resistors are available in non-inductive versions. No matter what you choose you would be best to check that they are non-inductive types.
Tony.
Tony.
