...excursion higher than 20mm p-p, and relatively high sensitivity?
4 454Casull Member Joined 2004 2004-04-30 10:03 pm #1 2004-04-30 10:03 pm #1 ...excursion higher than 20mm p-p, and relatively high sensitivity? ••• More options Share ingvar ahlberg Member Joined 2004 2004-04-30 10:09 pm #2 2004-04-30 10:09 pm #2 Check out TC sounds, they´ve got some nice units, otherwise RCF and PHL has nice drivers matching Your description except for X-max. ••• More options Share Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button.
