Hi
Where can i find a good case(europe) for the diy sony vfet or other Pass amp? i know this is all about diy but at the moment i don't have the time to build one. I really need to finish the project in dual mono's
Thanks for any help.
Modushop by Hi-Fi 2000 | Contenitori per Elettronica | Electronic Enclosures | Hi Fi Chassis
though , sometimes is hard to make physical organization of output devices on two sides of case
for instance , sony vfet amp is better to make as dual mono , in one case
4U/400 , with inner base plate is more than adequate solution
I have an F5 in modushop case. I was thinking that 2 mono amps in the same case may not be a good idea.
What do you think? The 4U/400 will handle it without problems? Noise or other kind of...
you see anything wrong or problematic here : Babelfish M25, SissySIT - general building tips and tricks ?
