Hi guys ,
I want to build a pair of 3-way economic reflex speakers ( ... possibly ) woofer 15 . " My room may contain speakers with measures ; height 100cm width 45cm depth 30cm . I have seen these speakers , cheap
http : // www . pyleaudio.com/products/Sound-and-Recording/Subwoofers---Midbass
..... else I find ..
If you have tips ide projects ... thanks
interesting, thanks....
you are in Italy get Faital Pro stuff. I can remommend two options:
#1:
15PR400 woofers 15" woofer
HF144 1.4" compression driver
LTH142 1.4" elliptical horn
#2:
15PR400 15" woofer
M5N8-80 5" midrange
HF100 1" compression driver
STH100 1" elliptical horn
in both cases sensitivity will be 99db@1w/1m
#1:
#2:
15PR400 15" woofer
M5N8-80 5" midrange
#1:
#2:
15PR400 15" woofer
M5N8-80 5" midrange
... Great products , but expensive for my pocket ...
If you can wait, buy used drivers off ebay or local to get the most for your money.
.ok wait Your news .. if you want you can send me a private message ..
Maybe lost in translation, but I was saying that if you look for used drivers in your area, you can build a pair of really good speakers for cheap. Look for pro woofers, mids, and tweeters. I am not selling anything.
.ok , clarified😀
#1:
#2:
15PR400 15" woofer
M5N8-80 5" midrange
That 5" m5n8 - do you have experience with it or some measurements ? I've been looking at it and it looks too good to be true.
While you are exploring diy-designs you could also check for used speakers for a couple months.
You will need to decide between compression driver + horn like Pi-Speakers, or standard dome tweeter.
P.S. The Clare website has several interesting designs....you should be able to find a topology you favor.
SB_Acoustics is considerd a good value in the USA. There are several diy passive crossover designs on the web. I attached one typical 3-way which uses a sealed midbass plus a ported woofer. This example uses :
SB29RDC-4 tweet $52
SB17NRXC35-8 midbass $58
SB23NRX-8 (8" woofer) $94
OPTION:
Dayton Audio DS315-8 (12" woofer) $75
You can construct a single cabinet, or enjoy mixing tops and bottoms. Check your local pricing for the drivers and crossover parts. Compare to a local used speaker.
SB29RDC-4 tweet $52
OPTION:
Depending on what you expect, your knowledge, woodworking, and what you consider cheap for a 3 ways with 15" subwoofer...Basically you can do this STX FX-300 (kolor orzech) - Nag?o?nienie STX + 4x 8" sub => 2 in opposite side in bass-reflex per columns adding 50-70 liters in each, for <200€ of drivers per columns. It should do 25-20khz. They got lot of stuff to do filters too. Really cheap for what it is.
Per column :
2 x 5" carbon cone with a lot of demodulation stuff W.18.180.8.FCX - Nag?o?nienie STX = 46€ x 2
dome tweeter with triple demodulation T.10.250.8.PCX - Nag?o?nienie STX = 33,5 €
2 x 8" subs : W.20.300.2x2.MC - Nag?o?nienie STX = 26,3€ x 2
= 178€ / column
Per column :
= 178€ / column
that was also very interesting to me. I just ordered a pair and I'll report back in a separate thread when it arrived. a 5" driver covering a wide frequency range and 99db efficient?! oh really? let's have a look at it up close and personal! 😀
... The problem is to buy in the US , is the customs in Italy is expensive ....While you are exploring diy-designs you could also check for used speakers for a couple months.
SB29RDC-4 tweet $52
OPTION:
Per column :
= 178€ / column
.this brand is really interesting , the products look good , the truly modest price .. Now ask them if ship to Italy . Thank you for advice ..
They shipped to me to France for only one 10" driver. Not si much problèmes beeing
understood by mail un english
There is too "compacbel.be" that are really cheap for sbacoustic speakers. Try contact them maybe. Since STX sold other stuffs usefull like filter component that make them even more interesting.
Great. Hope it lives up to expectations 🙂
- 3way con woofer 15" ... possibly economic!!!
