Hello,
I have built a vented enclosure for the woofer I was talking about in my recent post, it sounds fantastic, even under 40hz but I am not loading it with full power.
The box is about 350l + interior parts. I am now experimenting with bottles of water but there is a drop at 36Hz. The rest sounds very nicely.
At first the box was about 315 l and then it had a drop from 48-60Hz. Now thats fine..
The port is tuned to 25,6 Hz
fs 28.2
re 5,2
D 338mm
qts 0,39
qms 5,47
qes 0,42
mms 106
bl 15
vas 330
cms 0,29
l1k 1,35
Rms 3,43
Sd 896
For how much should I increase or decrease if this happens? I mean Could one liter or half a liter make a difference? or should I just move by 5 liters +5 +5...
fs 28.2
re 5,2
D 338mm
qts 0,39
qms 5,47
qes 0,42
mms 106
bl 15
vas 330
cms 0,29
l1k 1,35
Rms 3,43
Sd 896
Can you measure the impedance curve, like with DATS or something.
Comparing that with a simulation will tell allot about what is happening including the resonance and if there are leaks at joints messing things up.
Dave
Dave
Changing a 315L box to 350L wont change anything much
with that driver, and certainly won't change 48-60Hz to
36Hz in any sensible reality, very poor measurements.
Room modes are likely the issue.
rgds, sreten.
rgds, sreten.
Yes it was the room.
I don't have the tools to measure the curve, the last time I tried to measure the ts parameters for a woofer they turned out different every time with a different weight and they were not usable at all.
Today I sorted everything out by using a computer based equaliser. The woofer sounds nice but it works only on low power. Otherwise it gives distortion.
But it is still a kickin feeling to hear and feel a self built audio system
I love this job
By the way what setup do you use for measuring ts parameters?
I love this job
