I have bottom mounted most parts on my SE board. The only problem is with U1. Can I mount it off board and just hard wire it, or must it be top mounted to the board? I can't preserve polarity with a bottom mount without wiring changes. If I do rewire to keep the I/O consistent, it would also make it easier to provide heat dissipation for the 300B's as well as make chassis selection easier. Thoughts from the crew????? Thanks!
