Simplest Amp I could Find (no output)
Hello,
I have 6 of these amps and they are all Identical. I am bound and determined to fix at least one of them by myself.
The amp is a power acoustic 620 Plasma sphere
I have 15vdc on the center leg of the power supply (50N06), I have 0v on all legs of the TL494CN. 0V on the output transistors (TIP35/36), and 0V all legs of all 4 of the KIA4558P.
I was a little trigger happy on the first post,
It was working for a second, and the green light was on, but not anymore. Now I have no voltage to the TL494, is one of the legs from the TL494 directly attached to the switched power?
I have a 5amp fuse and I am powering up via a larger 8ohm resistor. the resistor is not getting hot at all.
I have 15v at the torrid transformer.
poking and prodding seems to have yielded some kind of results. The amp came to life and now has output voltage that can drive a speaker. It sounds very scratchy but it could be the test speaker. I will put the amp back together and put it in a car and test it.
The pin 12 is not simply behind a diode. it seems to go to a voltage regulator (TO-220)(Q2)and there seems to be a couple of dividers that make it too difficult to accurately (quickly) draw a diagram.
Q2 appears to be the switch that supply B+ to Pin 12 of the 494.
If the transistor is weak the B+ line to Pin 12 of the 494 will become erratic and power to be intermittent. Check the voltage at Q2's middle leg and Pin 12 for a stable 14 volts or better.
