Just picked up one of those - and picked up is a very very loose term, no way I am picking this thing up without a engine lift ever again.
So its blowing the 1.2 amp fuse. The seller said he connected up the speakers without warming it up and hence it blew that fuse -
I am not sure that is right - so I need to find why and fix it.
Thanks.
Srinath.
Thanks.
Srinath.
Thanks.
Srinath.
The small fuse is for the fan and input circuit. See if the fan blade can be easily turned, maybe it's bad. That would be an easy fix.
Service manual: http://www.crownaudio.com/media/pdf/legacy/ma600sm.pdf
Thanks, I'll check it, as soon as I lift it out of the back seat of the car and onto the work table (the tailgate of my truck)
Cool.
Srinath.
Cool.
Srinath.
Is the amp an M600 or an MA-600?
http://www.crownaudio.com/legacamp.htm
Service manuals and schematics are available above.
M600 - I think.
I have to look more carefully @ it I guess. LOL.
M600 also has fan circuit is a separate fuse and has a 1.2 a fuse.
MA is macro tech - Mine is not macro tech, so M600.
Cool.
Srinath.
Cool.
Srinath.
Correctol ... Laboratory power amp ... designed to run a MRI coil, or other crazy equipment ... yes, sitting on the floor of my garage.
That thing in front with 2 thumb screws ... WTH is that ?
Thanks.
Srinath.
Thanks.
Srinath.
- Crown M 600 blowing the 1.2 amp fuse - not the 20 amp fuse
