Difference between PA/home/car drivers
im trying to figure out the differences here
why do PA drivers usually use double/triple roll surrounds?
what makes PA drivers so efficient?
would a home/car driver inside a cabinet designed for very large open areas be the same as the recommended enclosure of a PA subwoofer?
PA drivers are efficient because they have poor bass for the cabinet size.
The surround is for progressive restriction of cone excursion, its not hifi.
Home and car drivers make poor PA drivers, and don't fit PA cabinets.
rgds, sreten.
Since you're in the "subwoofers section",
Home subs - go low while sounding nice. Real SPL is rarely a concern.
Car subs - go low and loud in tiny boxes. Usually requires a lot of power.
PA subs - go very loud, survive not-inconsiderable abuse (see sreten's post above), and still be portable. Usually don't go particularly low.
All just different options in Hoffman's Iron Law.
Chris
Car drivers can work quite well in front-loaded horns for PA use, the box will be quite large if any real bass is to be developed (as with any fron'load horn).
PA drivers can make great home theater subs when used in a tapped horn type enclosure.
