HI-there i"m new to this forum - but have some strange problem with my new amp - just received it from USA couple of days - it have number of problems - most of them damaged tubes- which i have replaced ...
played it for an about 2 hours.....next day tryed turn it on - and had a blown fuse ....rechecked the tubes - one rectifier had some smoke on the glass near the base - replaced it - still have blown fuses -tryed turn on standby it with no tubes at all- blown fuse and see flash in the midle rectifier socket
opened it up -found slight burn on the (Bold/Spongy) switch-tryed it with Tester- shorting all legs in any positions?!
what it's might be?
please help!
Looks like that guy which sold it to me- kept it in very wet place some time-the amp is not so old- but shows signs of corrosion
what it's might be?
please help!
that it- i found it's near the second rectifier socket - when pull the PCB out ....there also - been slightly smoked rectifier which i have removed
looks like the tube caused burn one of diodes ?!
I'm afraid something happened to power transformer 🙁
as i told (bold/spongy) switch is shorting in any positions -so the two black wires which he must connect in one or other position going straight to the power transformer
from left -switch between tube and diode rectification - it works(2grey wire)
next- tree legs switch (bold/spongy) is the one which shorting - left and right wire going to the power transformer middle to Standby->Fuse and power socket
the burned place on the PCB it's burned path between second and third tubes
i have tryed tube and diode modes- the fuse blows in two cases
How can i Fix ? any help? -to take out the diodes for check ? to fix the burned path with piece of wire?!
How was the amp shipped to Israel, and are you sure it is configured for 230V operation? Was it insured?
ok-thanks
no insuranse- used amp 🙁
shipped with the UPS,in soft padded box -visually don't have any damage
i'm using it with step down automatic power transformer-1000 VA
it's not my firs amp shipped overseas- i'm already have Trevor Frenzel builded 100watt head and Carvin Bass Head
- Live Sound
- Instruments and Amps
- Mesa Triple - shorting in the(bold/spongy) switch!?
