question about vented pole piece and slim cab
It would change operating conditions and radiation a bit, but more importantly I see some basic problem with it... noise at higher excursion, quite likely actually. And I wouldn't do it with drivers that have *good* ventilation around/through the voice coil former (perforated former), which means an easy path with strong coupling between back of cone and air under the dustcap. You'd move much more air through the driver than intended and designed for and it will most certainly fart.
Is it a mid driver? Can remove dust cap and vent thru the front of speaker.
Taking off the dust cap "opens them up" a bit.
Either dap a bit of glue on the vent hole and insert a foam disk, or make a wood phase plug and use long screw.
I wouldn't think to do this in a expensive/new driver, but the cap can be glued back on if it doesn't work out.
I would suggest not to play dirty tricks with drivers as good as Accuton's 😀
Maybe you can cut out a rather large section of the back panel and seal with a thick aluminum plate or a solid plastic cup to make enough room behind the vent.
strange question, but if I had a cabinet that was the depth of the driver and it was jammed against the back, cd i let it vent through a hole in the cabinet?
Venting of the pole to the outside air definitely provides a thermal advantage.
As mentioned, the vent noise may not be acceptable, but generally noise from a rear vent would be masked by high frequencies at high drive levels.
The vent hole should be surrounded by a gasket rather than being "jammed against the back" to avoid changing the cabinet tuning.
A gasket can easily be made by running a bead of silicon caulk around the vent hole, allow it to cure before installing the speaker.
Won't the LF output from the pole-piece vent be out of phase with the main radiation from the speaker?
Cabinet tuning could get very interesting.
The output radiated from the vent is reversed polarity from the forward radiation of the cone whether inside or outside the cabinet.
I have done push-pull tests where one vent was inside, one was outside, frequency response was virtually identical, the output radiated from the vent is so small in comparison to the driver SD it has no consequence in output or tuning compared to the same cabinet with both vents inward.
The only down side is potential vent noise, which may or may not be a problem, completely speaker and excursion related.
The up side is better cooling at high drive levels.
Art
