I have a Lepai 2020 hooked up to 2 of these: TS-G4643R - 4" x 6" 2-Way Speaker with 130 Watts Max. Power | Pioneer Electronics USA
I wanted too hook up either a sub or another 4 inch 2 way....in total 3 speakers on a 2 channel and, how would i do that??!
You can buy an active subwoofer made by Polk or Velodyne at Fry's for about
a hundred bucks. They work fine, will wire right in, and have some crossover
and level controls.
and level controls.
Velodyne subs, for example, here is one from Fry's as Mr Pass mentioned. It is way more than $100 though.
FRYS.com | VELODYNE
FRYS.com | VELODYNE
A word of caution:
From what I know of T-amps (which isn't much), they cannot be connected to a sub with speaker wire inputs unless an special adapter is used. With the T-amps I have, both the black & red terminals are 'hot'; the sub assumes common ground for the speaker wire inputs & just ties the neutral lines together. I have been told that if you tie the two 'neutral' lines from a T-amp together, the amp will release the magic smoke.
I never tried/tested this, as I don't want to lose an amp.
As always: check with a knowledgeable person before proceeding--like going over to the forum where folks are building T-amps and have experience.
Cheers, Jim
Cheers, Jim
- Full Range
- Question
