I'd like to help, but need some more info. What cab alignment are you wanting to utilize.....sealed, vented, BP, horn, etc.? Do you already have the driver, if so bear in mind that with a qts of 0.3 that driver is going to fall like a brick below fs, and doesn't have enough xmax to eq the low end in a more conventional cab......really needs a horn IMO. I assume you're limited in India as to what is cost effective shipping wise........this is a much better choice from the same distributor........http://www.ahujaradios.com/ProductSpecification.asp?prd_id=198&id=7&sc_id=48
I'd like to help, but need some more info. What cab alignment are you wanting to utilize.....sealed, vented, BP, horn, etc.? Do you already have the driver, if so bear in mind that with a qts of 0.3 that driver is going to fall like a brick below fs, and doesn't have enough xmax to eq the low end in a more conventional cab......really needs a horn IMO. I assume you're limited in India as to what is cost effective shipping wise........this is a much better choice from the same distributor........Ahuja Sound Solutions
hello sir
i want to use this for out door purpose (200 people gathering) so you decide me the cab alignment
i have already purchased driver
thank you
I think I would use that in the SS15 tapped horn.
http://www.diyaudio.com/forums/subwoofers/170771-single-sheet-th-challenge.html
my experience from thai people. bp6 [18"*4] can play with party about 70 table. one table is about 5-6 persons. therefore people are about 400 in party.
with ur driver is very low x-max. i think this driver play midbass more than low deep. the possible likes djk said cubo is the best way to go. horn can increase spl with the low x-max more than any types. the cubo i think that's very hot now. last week i post on thai forum but use with p audio.🙂
- Subwoofers
- sub-woofer enclosure
