Front panel construction - help with buttons!
I'm working on a PC based source component of sorts and I'm at a point where I need to put it in a chassis. I'm going to get the front panel from Front Panel Express. It's a basic front panel consisting of about a dozen buttons (monentary SPST) and a small LCD display from Matrix Orbital.
I'm struggling with the buttons. Looking at this picture here:
http://www.briangt.com/gallery/cdpro2/cdp02
The actual button cover that you press to activate the switch on the PCB behind the front panel - they're just little pieces of plastic or aluminum with a ridge around the edge so they stay in. Is there a term for those? Where do you get them?
I'd like some aluminum ones I could find some.
Are they tactile switches behind the front panel?
If so I believe they are known as "switch caps" Only ever seen cheap plastic ones never seen aluminum ones.
switch caps
I had the same problem when building my cd player. In the end I layered acrylic to create a button.
cd player
If you want aluminum ones (which is also what I originally wanted and still do) I would find someone with a center lathe. I do know some one who could do it but I'm sure there must be someone more local to you.
