My work! LM4766 Full balanced
To build a stereo amp, I plan to use 8*LM4766!😀
I just finished PCB project with Protel DXP
Each board uses power regulator build with 5-10 mA current source and LM431 (adjust it to 32V)
Here is some PICs about it ,but I have not make real PCB out yet😎
Re: Re: sch
bbp said:
my english is so so so poor:bawling:
peranders said:
I haven't seen any signs of this yet :no: Your english is quite alright. :nod: :up:
Are you really usre about the parallel connection? :scratch: Don't you need any resistors in series as the rest of the world does?
The post#1 shows the real schematic ,and post#3 only shows the theory,not the one I really want to build
On the PCB, I will use 4 * 0.47-1 omega resistors on each board.
bbp said:
Many OP can drive 600ohm impedance easily, for example,LM4562
I agree that many opamps can drive 600ohms but NOT easily.
I think only a few can achieve good 600ohm capability.
Check how much distortion degrades as load impedance is lowered.
Remember also that the NFB is parallel to the output and both must be driven. Then add a bit of extra current feeding any parallel capacitance (this reduces the HF impedance even further).
