SMALL horn bookshelf ?
All,
I recall somewhere seeing a small folded horn bookshelf. It looked to use a 4-6" driver. Judging off of that, it seemed to be about 12" high, by 8" wide, by perhaps 16" deep. Anyone ? Would there be a benefit of a small horn over a bass reflex design ? Sorry, but I am obviously a FR noob.
I'm currently building a low powered (4-6w) SE amp for my bedroom, and space is a premium (The amp itself is going to fit inside a jewelry box). All I am after would be response down to 65hz or so; as I have a feeling the tiny OPT's I am using roll off below 55hz anyway.
Thanks !
Steve
Gents,
Thanks for the help - Sreten, those bookshelves sure look tempting; 94db would be an excellent match for the amp and room size.
Anyone else ?
I was looking at planet 10's fronken box. Im sure it would be an excellent match as well; but I don't have a table saw, etc. So that kinda puts it out of the running.
Thanks !
Steve
Anything that small isn't really going to be a horn, but a TL variation... doesn't really matter as long as it works....
I have a set of BK101s on my test bencg that work wonderfully... (no tweeter used anymore)
original plans attached
dave
It cracked me up to see that old box lying on that even older persian rug. Both the box - now painted with blackish fleckstone and still playing at uncle Elis appartment, and the rug exist.
When i built it i think i estimated the spacing between panels.
The speakers actually make music with a RS 1197. Great sound for the $$$ but still best with a sub IMO. Today if i decided to build them again id use pine rather than mdf.
Thanks,
Godzilla
94 dB is probably a bit optimistic. Factory on the driver is 93 dB, and the average of 40 units i've actually measured is about a 1/2 dB less than that. The 126 really doesn't work all that well in a BR, an FE127 is a better bet here.
dave
Have you checked the box plans recently? 3 easier to build variations of the Fonken are now up (2 of them floorstanding). I haven't done a simple BR based on the Fonken tuning but Rabbitz BR is probably close to what that would look like.
dave
dave
The apparent 93-94 dB sensitivity cannot be achieved in a small vented construction. It would be much too bright.
Thus the overall response is tuned for a ~89 dB sensitivity, but this is not bad at all for a mini.
Many similar constructions may only reach 80 dB/2.8V/1m.
planet10 said:
The 126 really doesn't work all that well in a BR.......
dave
I've tried cross-calculation on the Fostex data (right) and something juts doesn't fit.
Cross-calculation on own data looks fine, but Mms is significantly higher and Qt
fortunately much higher, making a vented cabinet more appropriate.
🙂/sreten.
Steven-H said:
Any idea on the width dim of the modified plans ? What driver would you recommend with this ? 126/166 ?
As Scott said, my drawing was for clarity, we followed the original (internal width = 173mm) ... This is designed for the FE103, I'm used FE103A (which required a supraBaffle after we tried to install the driver and found the extra deep magnet wouldn't alow the flange to meet the baffle), and Jeff used the Radio Shack 40-1197.
dave
