| Home | Forums | Articles | Gallery | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Tubes / Valves All about our sweet vacuum tubes :) |
Please consider donating to help us continue to serve you.
Ads on/off / Custom Title / More PMs / More album space / Advanced printing & mass image saving |
Thread Tools |
#1 |
diyAudio Member
The industry was pretty good about standardization. If you take a 6SN7 and a 12SN7 you know that except for the filament ratings the tubes are identical.
My questiion is why is the 6L6 family not the same family as the 12L6, 25L6, 50L6? These higher filament voltage derivatives sharing the same name are wimpy 10 watt PD tubes which match the 6W6, whereas the 6L6 is a serious PD output tube, in any of it's incarnations. 6L6, 6L6G, 6L6 GB = 19 watts PD. 6L6GC=30 watts PD. Comments on why? In a world gone mad with inconsistencies, this example baffles me.
__________________
Cheers, Bob Palindrome Effective single question I.Q.Test. Q: Have you ever purchased a recreational snowmobile? |
#2 |
diyAudio Member
I am not sure, but the 6L6G is designed from the 807 tube family that is actually a transmitting tube. The 12L6, 25L6, etc should have been a new number such as 12J6GT.
#3 | |||
diyAudio Member
Quote:
Quote:
Quote:
Also take a lookitdis (see attached). The 50C5 has a 50V heater, and the 25C5 has a 25V heater, so far, so good. The 17C5 has a 16.8V heater, so they rounded up. But the 12C5 has a 12.6V heater, so shouldn't this be called a 13C5? Or shouldn't the 17C5 be called a 16C5 instead? There is no consistancy here at all. Reusing type designators like **C5 or **L6 should not have been allowed, and they should have decided: round heater voltages up or use the whole number part as the leading type number. But that's not how things worked out.
#4 | |
diyAudio Member
Quote:
__________________
Best-ever T/S parameter spreadsheet. http://www.diyaudio.com/forums/attachment.php?s=&postid=353269&stamp=1079781945 |
#5 |
diyAudio Member
Ye-e-e-e-s!
Just to echo. At the time (from someone who was there then - but I also still have all my hair, rcavictim), the logic (sic) seemed to have been that beam power tubes were ...L6s, that is the octal types. "6" for the number of electrodes - but then 117L7 or 70L7 had 2 extra electrodes by way of a built-in rectifier, so should have been ...L8s. As far as I know "L" seemed to have come from the German for "power tube", i.e. Leistungsrohre (dots on the "o") - but they again had a totally different numbering system. Logic, such as it was, seemed to have been limited to 6V types - well, in a way. Welcome to the well-defined world of electronics. Regards. |
#6 |
GlassFET
diyAudio Member
Heh, forgot to add 50L6, different again
__________________
-= Gregg =- "Ratings are for transistors...tubes have guidelines" Hobby and communites - GeeK ZonE Commercial site - classicvalve.ca diyAudio Blog - GeeK's Bench |
#7 | |
diyAudio Member
Quote:
__________________
#8 | |
GlassFET
diyAudio Member
Quote:
__________________
#9 |
diyAudio Member
Obviously the 1L6 must be related to the 6L6 and 50L6 as well
![]() 6BY7 is not like 12BY7 6AB5 is not like 12AB5 6K5 is NOTHING like 12K5 6A7 and 12A7 are not even close. How close is a 6B4 to a 12B4? |
#10 |
diyAudio Member
Location: kansas city mo, and on occasion, around the world ...
Originally posted by Tom Bavis
Obviously the 1L6 must be... ``````````````````````````````````` was only for/used in one thing... http://antiqueradio.org/art/zen18.jpg |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 32 NOS RCA 1644 (12L6-GT) Twin Pentode tubes | karma | Tubes / Valves | 8 | 12th September 2009 11:30 AM |
| FS tube tuner, Active filter kit, tube amp, amp3 | Josephjcole | Swap Meet | 9 | 20th July 2007 05:05 PM |
| SS or tube voltage amplifying stages in an amp with tube output? | ray_moth | Tubes / Valves | 14 | 4th July 2007 04:09 AM |
| need diy tube preamp (line-stage) recommendation and general tube advice | Musiclover4 | Tubes / Valves | 15 | 24th November 2005 02:19 AM |
| tube driving the same tube - whats the collective word? | zobsky | Tubes / Valves | 3 | 13th June 2005 07:47 AM |
| New To Site? | Need Help? |
| Page generated in 0.11459398 seconds (82.08% PHP - 17.92% MySQL) with 11 queries |
