Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 11th January 2016, 07:44 PM   #481
OYDES is offline OYDES  France
Default 5V and Amanero on HQ AUDIO with Lundahl trans
I wish to use USB cāble with independant 5 volts with my dac and I have a question:
Dif AMANERO cards is with an independent 5 volts in the HQ AUDIO Dac with Lundahl Output ?
Or may I have to add a supply 5 volts outside the DAC to feed an USB cable ?
Hope that you understand my bad english, sorry.
Old 12th January 2016, 01:19 AM   #482
linuxfan is offline linuxfan  Australia
Amanero external powering was explained by Quanghao back in April 2013 -
http://www.diyaudio.com/forums/quang...ml#post3435398
Two points:
- the Amanero board must be modified to disable the incoming USB 5V power
- 3.3V USB supply on the DAC-END-R must be enabled with a jumper - J3 on ver1 DAC, or J11 on ver2 DAC.
Old 13th January 2016, 05:42 AM   #483
Hi Linuxfazn,
Thank you very much for your answer.
Regards.
DAC-END R (ES9018) full assembled board - version 2 - group 2Hide this!Advertise here!
DAC-END R (ES9018) full assembled board - version 2 audiodesign Quanghao Audio Design 1163 2nd March 2018 08:41 PM
DIY ES9018 Hi-end USB DAC spirovious Digital Line Level 317 28th February 2018 07:21 AM
DAC-END R (ES9018) full assembled board audiodesign Quanghao Audio Design 2311 19th June 2017 02:21 AM
DAC-END R (ES9018) quanghao Digital Source 168 22nd June 2013 12:13 PM
DAC ES9018 Evaluation Board / No Output ghmfranken Digital Line Level 7 15th January 2013 08:13 PM
