Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 10th July 2014, 02:56 AM   #21
quanghao is online now quanghao  Viet Nam
DAC-END R (ES9018) full assembled board - version 2 - group 2 Send a message via Yahoo to quanghao DAC-END R (ES9018) full assembled board - version 2 - group 2
Originally Posted by akltam View Post
Thank you Linuxfan,
I do not mean on this particular board what you need to set on this board to make it current out or voltage out.
I mean in general what is needed to make a ES9018 current out or voltage out. If I am to use this board as a reference, when you put in jumper, what exactly are you connecting to make it current out ? When you remove the jumper, what exactly are you disconnecting to make it voltage out ?
Thanks.
Alan I
Hi
Hereby on request the User Manual.
Old 10th July 2014, 04:55 AM   #22
audiodesign is offline audiodesign  Italy
Banned
Send a message via MSN to audiodesign DAC-END R (ES9018) full assembled board - version 2 - group 2
Here a system created for a my friend with this DAC
http://www.audiodesignguide.com/HiRe...diacenter.html
Old 10th July 2014, 10:53 PM   #23
feriandas is offline feriandas  United States
GROUP BUY LIST
1. atterbud - - (Option 9) complete assembled DAC with Lundahl LL1684 output stage $1250
2. bsy020 - Option 6 full DAC (standard output) + PCBs for Transformer output
3. Abszero!
4. Gugi 100 (dacboard, output board, chassis)
5. smokingdog
6. feriandas - (Option 8) DAC module + amanero + DD output stage + transformer 115V + chassis
7. ivigueras: 1 + 2 + 3 (DAC, DD output stage, chassis)
8. Djauweh - Option 9 Complete assembled DAC with Lundahl LL1684 output stage
9. audiomusica - Complete set (option 1+2+3+4+5) assuming this makes a complete kit like option 6 but finally assembled on my own.
10. bamarek - option 9 - complete assembled DAC with LL1684
11. Sugden (option 9) Complete assembled DAC with Lundahl LL1684 output stage
12. Nicos - DAC module + amanero + output stage + transformer + chassis (Complete set: Item 6)
13. mjensen (option 9) - complete assembled DAC with Lundahl LL1684 output stage
14.ingemar (option 9)- complete assembled Dac with Lundahl LL1684 output stage(i need to bail out,sorry!!)
15.Gergar- (option 9) - complete Dac with LL1684 + 2 DD output + Op-amp output
16.rolandong-Dac module (assembled & tested with all components) + Amanero module + Aluminum remote
17. Losflacos (Option 9) complete assembled DAC with Lundahl LL1684 output stage, (240VAC) + aluminium remote control
18. picknicker - option 1 + 5: (DAC module assembled and tested with all components + Amanero module) - please also add the metal remote
19. akltam (option 9) complete assembled DAC with Lundahl LL1684 output stage (230V) + remote control
20. Thom - Assembled kit without any output stage (1+3+4+5) + aluminium remote (I will use my own output stage).
21. Alexkosha (option 9) -> complete assembled DAC with Lundahl LL1684 output stage (115V) + Aluminum remote control
22. ruteksen (option 2 + 5) -> output stage + amanero
23. mirza - option 9 completed & assembled DAC with LL 1684 - 230V, aluminium remote controle
24. Artur5 - DAC module and Amanero USB board,.
25. Myint67- option 9 complete &assembled dad with ll 1684 -230v aluminium remote control
26. marcus1 (option 9) complete assembled DAC with Lundahl LL1684 output stage (230V)
27. nick696 - (Option 9) complete assembled DAC with Lundahl LL1684 output stage, (240VAC) + aluminium remote control
28. Audioheaven option 1-2-5
29. nick696 - (Option 9) complete assembled DAC with Lundahl LL1684 output stage, (240VAC) + aluminium remote control
30. reins - option 1-2-5 -> DAC, output stage, amanero
31. Erlend Sæterdal - option 2 -> output stage only
Updated to reflect the new order classification.
Old 12th July 2014, 12:23 PM   #24
typn1979 is offline typn1979  Viet Nam
GROUP BUY LIST
3. Abszero!
5. smokingdog
32. Typn1979 - option 9 with 220v output + remote control
Old 13th July 2014, 03:16 AM   #25
GROUP BUY LIST
3. Abszero!
5. smokingdog
Typn1979: removed from the list while considering another option
Old 13th July 2014, 09:07 PM   #26
juju35135 is offline juju35135  France
GROUP BUY LIST
3. Abszero!
5. smokingdog
Old 13th July 2014, 09:09 PM   #27
GROUP BUY LIST
3. Abszero!
5. smokingdog
32. juju35135 - "Option 9" : NoPowerTR/DacBase/LL PCB ONLY/ArmarenoUSB : Paid 1250+150 $USD
Old 14th July 2014, 12:23 PM   #28
akltam is offline akltam  Hong Kong
Hi, Quanghao
Is the size and the position of the Discrete Transistor board and the output transformer board interchangeable ?
I am thinking to order option 8 (with the Discrete Transistor) and then order the transformer & Board separately so that I can try out both options.
Alan
Old 14th July 2014, 02:22 PM   #29
Apogee is offline Apogee  United States
Apogee's Avatar
Hi, Quanghao
Alan
Alan,
Yes, they are interchangable. I've ordered mine exactly as you describe for the same reason.
Kind regards,
Steve
"If I had my life to live over again, I would have made a rule to read some poetry and listen to some music at least once a week." - Charles Darwin
Old 14th July 2014, 06:35 PM   #30
mjensen is offline mjensen  Denmark
GROUP BUY LIST
3. Abszero!
5. smokingdog
13. mjensen (option 8) - complete assembled DAC with the discrete output stage + PCBs for LL1684 output stage
mjensen: changed my order to option 8.
DAC-END R (ES9018) full assembled board - version 2 - group 2Hide this!Advertise here!
DAC-END R (ES9018) full assembled board - version 2 audiodesign Quanghao Audio Design 1163 2nd March 2018 08:41 PM
DIY ES9018 Hi-end USB DAC spirovious Digital Line Level 317 28th February 2018 07:21 AM
DAC-END R (ES9018) full assembled board audiodesign Quanghao Audio Design 2311 19th June 2017 02:21 AM
DAC-END R (ES9018) quanghao Digital Source 168 22nd June 2013 12:13 PM
DAC ES9018 Evaluation Board / No Output ghmfranken Digital Line Level 7 15th January 2013 08:13 PM
