Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 29th September 2013, 06:54 PM   #21
papapew is offline papapew  United States
Very Interested.
Would this be available as a kit with all the SMD devices mounted?
I would like to do a bit of DIY to save some money.
Old 29th September 2013, 07:35 PM   #22
smokingdog is offline smokingdog
I am interested in this DAC also. But I cannot see where to register for Grouo Buy 2. Where can I register for Group Buy 2?
Old 1st October 2013, 08:29 AM   #23
audiodesign is offline audiodesign  Italy
Banned
Send a message via MSN to audiodesign DAC-END R (ES9018) full assembled board - version 2
Please write your name in the list below and choose you want to:
1. adeveza DAC module + output stage
2. papapew DAC module + output stage
3. smokingdog DAC module + output stage
20 the end .
add or remove options, like output stage, chasise transformers, Amanero usb module
Old 1st October 2013, 03:39 PM   #24
adeveza is offline adeveza  United States
Sorry, but where is the list? to put our name?
Old 1st October 2013, 05:26 PM   #25
linuxfan is offline linuxfan  Australia
audiodesign (Andrea) just created the list. You're first on the list.
A GB list is progressive; every new participant should ADD to the list.
Old 1st October 2013, 05:32 PM   #26
Hi Quang Hao and Andrea,
I'm impatient for more information about the discrete output stage!
Earlier you indicated that the power supply is still being developed, but is the main circuit tested and working?
Are you happy with the sound?
What's the current draw?
Old 1st October 2013, 05:56 PM   #27
linuxfan, where is this list that audiodesign created? I know, he probably put my name in it, but where is it?
Old 1st October 2013, 06:07 PM   #28
NicMac is offline NicMac  Italy
NicMac's Avatar
in post #23
Old 1st October 2013, 08:36 PM   #29
gde3 is offline gde3
4. gde3 DAC module + amanero
Old 1st October 2013, 08:44 PM   #30
Banned
Quanghao have tested the new shunt without op-amp on a single power supply of the first DAC module and the sound is good, no differences and less problems to keep it stable.
We have tested the new output stage with a prototype on one channel and the result is much better than op-amp.
In any case I think that Quanghao will produce a first little series of few pcb, 2 or 3 items, to test if all is ok.
DAC-END R (ES9018) full assembled board - version 2Hide this!Advertise here!
DIY ES9018 Hi-end USB DAC spirovious Digital Line Level 291 26th July 2017 01:11 PM
DAC-END R (ES9018) full assembled board audiodesign Quanghao Audio Design 2311 19th June 2017 03:21 AM
DAC-END R (ES9018) quanghao Digital Source 168 22nd June 2013 01:13 PM
DAC ES9018 Evaluation Board / No Output ghmfranken Digital Line Level 7 15th January 2013 09:13 PM
Another DIY ESS ES9018 Sabre DAC board Trevor White Digital Line Level 4 19th August 2010 03:41 PM
