Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 15th November 2017, 04:12 AM   #1161
adeveza is offline adeveza  United States
Originally Posted by linuxfan View Post
Use the header block which is provided to connect an Amanero board. Pin assignment is as per the Amanero spec sheet -
3 I2S DATA / DSD1
4 I2S BCLK / DSD CLK
5 I2S FSCLK / DSD2
Use the pins on the opposite side of the header block for grounds - 13, 14, 15.
Alternatively, in front of the Amanero header block are 10 holes, in 2 rows of 5. These carry the same connections, but in a different order:
2 BCLK
3 DATA1
4 DATA2 (FSCLK)
If you solder a header here, you can use a standard ribbon cable/plug assembly for connection, and this pin order is more likely to match other I2S output devices, than the Amanero pin order does.
Ok, I tried this connection. I took out Amanero and connect the I2S from my source as described. No Lock, No sound, then I connect a 3.3v to the pin where amanero says 3.3v in it, and it works, now the question is, is there a way where I dont have to provide this 3.3v? maybe a jumper on the board itself, where the board will provide the 3.3v?
Quanghao, can you provide some explanation on this one?
Alex
Old 2nd March 2018, 05:37 AM   #1162
alexkosha is offline alexkosha  United States
alexkosha's Avatar
DAC-END R (ES9018) full assembled board - version 2
Hi guys, can you please share with your JRiver setup for V2 Guang Hao DAC. Canít set it right on last released player version for Win. Or it is plays PCM 44.1 fine or DSD up to 256. Canít find final setting witch accommodates both. V2 DAC online setup instructions are outdated since they are applicable for quite old JRiver player. Images will be very helpful. Thank you in advance.
Old 2nd March 2018, 08:38 PM   #1163
alexkosha's Avatar
Can you send me a link to it? Thank you.
Old 2nd March 2018, 08:41 PM   #1164
caad is offline caad  Denmark
hi the User manual are 1.7MB and Max upload on the forum are 1MB. please PM your email and i will email it to you
Br
Caad
DAC-END R (ES9018) full assembled board - version 2Hide this!Advertise here!
DIY ES9018 Hi-end USB DAC spirovious Digital Line Level 317 28th February 2018 07:21 AM
DAC-END R (ES9018) full assembled board audiodesign Quanghao Audio Design 2311 19th June 2017 02:21 AM
DAC-END R (ES9018) quanghao Digital Source 168 22nd June 2013 12:13 PM
DAC ES9018 Evaluation Board / No Output ghmfranken Digital Line Level 7 15th January 2013 08:13 PM
Another DIY ESS ES9018 Sabre DAC board Trevor White Digital Line Level 4 19th August 2010 02:41 PM
