Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 7th August 2017, 05:56 PM   #1151
hego is offline hego  Europe
Any mod for up the audio level ouput?
Cheers
Old 21st October 2017, 02:16 PM   #1152
onepiece01 is offline onepiece01  Thailand
Hello,
Sorry i have trouble(MY HQ reference DAC ES9018S)
USB Input signal sometime it is lock but sometime it nolock.
Why it occurs like this and how to adjust?
thanks.
Old 27th October 2017, 05:52 AM   #1153
Originally Posted by onepiece01 View Post
Hello,
thanks.
81552 - Sendvid
Old 13th November 2017, 10:24 PM   #1154
adeveza is offline adeveza  United States
Default I2S Input
Anybody knows how input I2S signal into this DAC? I have an SD player that output I2S and I want to use this DAC instead of using USB. Can anyone please help? Quanhao, can you please help?
Alex
Old 13th November 2017, 10:34 PM   #1155
Erlend Sæterdal is offline Erlend Sæterdal  Denmark
DAC-END R (ES9018) full assembled board - version 2
Cheers
Change resistors to Takman carbon and filter capacitors to polystyren. BURSON V6 AS OPAMPS.
Old 14th November 2017, 12:06 PM   #1156
linuxfan is offline linuxfan  Australia
Use the header block which is provided to connect an Amanero board. Pin assignment is as per the Amanero spec sheet -
3 I2S DATA / DSD1
4 I2S BCLK / DSD CLK
5 I2S FSCLK / DSD2
Use the pins on the opposite side of the header block for grounds - 13, 14, 15.
Alternatively, in front of the Amanero header block are 10 holes, in 2 rows of 5. These carry the same connections, but in a different order:
2 BCLK
3 DATA1
4 DATA2 (FSCLK)
If you solder a header here, you can use a standard ribbon cable/plug assembly for connection, and this pin order is more likely to match other I2S output devices, than the Amanero pin order does.
Old 14th November 2017, 01:48 PM   #1157
quanghao is offline quanghao  Viet Nam
DAC-END R (ES9018) full assembled board - version 2 Send a message via Yahoo to quanghao DAC-END R (ES9018) full assembled board - version 2
[QUOTE=linuxfan;
hi please see image!
thanks
quanghao
Old 14th November 2017, 05:11 PM   #1158
3 I2S DATA / DSD1
5 I2S FSCLK / DSD2
2 BCLK
3 DATA1
4 DATA2 (FSCLK)
Thanks guys, Quanghao image is also helpful.
Alex
Old 14th November 2017, 08:04 PM   #1159
[QUOTE=quanghao;5243695][QUOTE=linuxfan;
thanks
quanghao[/QUOTE]
Looks like the board was designed to use some kind of female connector, can anyone recognize what type of connector it is that will go into those 5 holes?
Alex
Old 15th November 2017, 03:50 AM   #1160
Ah, the 2 rows of holes I mentioned are on the version 1 DAC.
On the version 2 DAC I think those circular-pattern holes are for U.FL or SMA connectors.
DAC-END R (ES9018) full assembled board - version 2Hide this!Advertise here!
DIY ES9018 Hi-end USB DAC spirovious Digital Line Level 306 22nd February 2018 05:28 PM
DAC-END R (ES9018) full assembled board audiodesign Quanghao Audio Design 2311 19th June 2017 03:21 AM
DAC-END R (ES9018) quanghao Digital Source 168 22nd June 2013 01:13 PM
DAC ES9018 Evaluation Board / No Output ghmfranken Digital Line Level 7 15th January 2013 09:13 PM
Another DIY ESS ES9018 Sabre DAC board Trevor White Digital Line Level 4 19th August 2010 03:41 PM
