DAC-END R (ES9018) full assembled board - version 2 - Page 86 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Quanghao Audio Design
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 24th June 2014, 07:27 AM   #851
Myint67 is offline Myint67  Singapore
Originally Posted by audiodesign View Post
Many jump are present to separate the power supply section to DAC section so these must not be touched.
There are others 4 jump near to the DAC module output to add the I/V resistors, these must be open with LL1684 output stage and discrete solid state.
The solid state output stage have some jump to change the voltage gain.
I will create a guide soon.
About the remote there is a guide with the first remote version on:
ES9018 USB DAC - Hi-Resolution System*
I will update soon with new remote but the fuctions are the same.
Hi DAC end r
Can update with famto clock ? .037 fs
Old 24th June 2014, 10:01 AM   #852
Hi, Hao!
I haven't understood you answer concerning damaged front panel.
I'm even ready to buy a new chassis with some discount.
Regards, Daniil.
Old 24th June 2014, 06:49 PM   #853
Hi Quanghao.
After discovering this thread thanks to Andrea, my only regret is that I came late and I've mised the first buy group.
Anyway, thanks for your great task and here comes the number 24 of your wish list.
1. atterbud - Option 6 full DAC build with Super I/V output stage in place of standard
2. bsy020 - Option 6 full DAC (standard output) + PCBs for Transformer output
3. Abszero!
4. Gugi 100 (dacboard, output board, chassis)
5. smokingdog
6. feriandas - DAC module + amanero + output stage + transformer + chassis (Complete set: Item 6)
7. ivigueras: 1 + 2 + 3 (DAC, DD output stage, chassis)
8. Djauweh - Option 9 Complete assembled DAC with Lundahl LL1684 output stage
9. audiomusica - Complete set (option 1+2+3+4+5) assuming this makes a complete kit like option 6 but finally assembled on my own.
10. bamarek - option 6 - complete assembled DAC with LL1684
11. Sugden (option 9) Complete assembled DAC with Lundahl LL1684 output stage
12. Nicos - DAC module + amanero + output stage + transformer + chassis (Complete set: Item 6)
13. mjensen (option 9) - complete assembled DAC with Lundahl LL1684 output stage
14.ingemar (option 9)- complete assembled Dac with Lundahl LL1684 output stage(i need to bail out,sorry!!)
15.Gergar- (option 9) - complete Dac with LL1684 + 2 DD output + Op-amp output
16.rolandong-Dac module (assembled & tested with all components) + Amanero module + Aluminum remote
17. Losflacos (Option 9) complete assembled DAC with Lundahl LL1684 output stage, (240VAC) + aluminium remote control
18. picknicker - option 1 + 5: (DAC module assembled and tested with all components + Amanero module) - please also add the metal remote
19. akltam (option 9) complete assembled DAC with Lundahl LL1684 output stage (230V) + remote control
20. Thom - Assembled kit without any output stage (1+3+4+5) + aluminium remote (I will use my own output stage).
21. Alexkosha (option 9) -> complete assembled DAC with Lundahl LL1684 output stage (115V) + Aluminum remote control
22. ruteksen (option 2 + 5) -> output stage + amanero
23. mirza - option 9 completed & assembled DAC with LL 1684 - 230V, aluminium remote controle
24. Artur5 -DAC module + Amanero.
17. Changed to option 9 from 6. Regards Losflacos.
Old 25th June 2014, 04:30 AM   #854
How to buy DAC end R option 9 with alu remote control for 1unit or can I add group ?
Old 25th June 2014, 05:25 AM   #855
Originally Posted by losflacos View Post
Hi Quanghao.
Hi hao ,
here comes the number 25 of your wish list.
Myint67
3. Abszero!
5. smokingdog
25. Myint67- option 9 complete &assembled dad with ll 1684 -230v aluminium remote control
Old 25th June 2014, 10:17 AM   #856
Banned
Send a message via MSN to audiodesign Send a message via Skype™ to audiodesign
Originally Posted by Algar_emi View Post
Hi quanghao. What are the I/V resistors on the DAC PCB? From what I can see they are 20R. Anyone tried better quality resistor at this critical location? Please quanghao confirm the resistor value?
SB
Yes, 20ohm
I suggest to you to use voltage output without these resistors (jump open).
Old 25th June 2014, 08:26 PM   #857
caad is offline caad  Denmark
Default User Manual
Hi All
Hereby on request the User Manual.
Br
Caad
Old 25th June 2014, 08:37 PM   #858
Ardahan is offline Ardahan  Turkey
Thank you Caad, it seems really nicely done
Old 25th June 2014, 09:30 PM   #859
Corpius is offline Corpius  Netherlands
Corpius's Avatar
Thumbs up +1
Originally Posted by caad View Post
Hi All
Br
Caad
Kudos for the user manual! highly appreciated!
CE-Designs.net
Old 26th June 2014, 08:37 AM   #860
marcus1's Avatar
Hi Quanghao.
I'm number 26 on the wish list.
cheers
marcus1
3. Abszero!
5. smokingdog
26. marcus1 (option 9) complete assembled DAC with Lundahl LL1684 output stage (230V)
DAC-END R (ES9018) full assembled board audiodesign Quanghao Audio Design 2301 Yesterday 11:47 AM
DIY ES9018 Hi-end USB DAC spirovious Digital Line Level 275 19th May 2016 11:43 AM
DAC-END R (ES9018) quanghao Digital Source 168 22nd June 2013 01:13 PM
DAC ES9018 Evaluation Board / No Output ghmfranken Digital Line Level 7 15th January 2013 09:13 PM
Another DIY ESS ES9018 Sabre DAC board Trevor White Digital Line Level 4 19th August 2010 03:41 PM
Copyright 1999-2017 diyAudio
