Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 11th May 2014, 12:14 PM   #2181
rredline is offline rredline  Singapore
Originally Posted by caad View Post
For change of bal to unbal and vica versa.
Press -s and +s on the frontpanel, at the same time.
Originally Posted by audiodesign View Post
1) I have compared now the code 58a and 64a but there is no difference in volume setting so both will work in the same mode
2) to set the default source after the switch-on enter in setting mode and press power/lcd botton to save this configuration
The volume is back after changing UnBal to Bal with the S-/S+ trick!
Thanks Andrea and caad.
The HiRes DSD on display just looks so cool!
Old 11th June 2014, 08:43 PM   #2182
smoothquark is offline smoothquark  United Kingdom
Any plans on producing a matching amp-end r? Would be a fantastic addition!
Old 17th June 2014, 05:45 AM   #2183
I'm thinking of upgrading the IV shunt's resistors and capacitors to metal foil and C0G, possible for me to have the resistors & capacitors values? Just a BOM for 1 IV Shunt would do (example: R5, R8: 10 Ohm, C4: xx nF, etc) ...Thanks.
Old 20th June 2014, 11:03 AM   #2184
PeterKD is offline PeterKD  Norway
Originally Posted by quanghao View Post
Here are the shipping rates for all,
Fedexl transfer, because I find shipping prices often cheaper than VNport not Fedexl and insecure.
I will declare the value as $ 50 to avoid import taxes for you!
invite you to check the price list, and for me full information in preparation for shipping next week. Thank you!
__________________________________________________ __________
I paid $100 for the shipping!
I received the new DAC to day. Have not tried it yet, but it looks very nice - both the inside and outside.
There is one thing: the on/off light does not work when pushing the on/off switch. The display is ok, but not the small diode. Can I do anything about it?
I looked inside the DAC and the connections look ok. Anything i can measure to fix this?
What if anything happens? I mean how do you repair any broken part of this DAC?
Do I have to send it all the way to Vietnam and back to Norway?
That will cost a lot of money!
Kind regards,
Peter
Old 20th June 2014, 11:06 AM   #2185
caad is offline caad  Denmark
Kind regards,
Peter
Hi..
There is NO on/off LED on the front panel of the DAC. The hole on the left side of the display is the IR receiver for the remote control..
Br
Caad
Old 20th June 2014, 12:44 PM   #2186
You are right - after starring at the DAC and the remote a few minutes i understood ;-)
Peter
Old 20th June 2014, 12:46 PM   #2187
You are right, of course. After starring at the DAC and the remote a few minutes it was abvious ;-)
Peter
Old 20th June 2014, 01:27 PM   #2188
Since the DAC has a volume control the power amp can be connected directly. Unbalanced. I only get a hum/noise - no music. Can anybody help me? I must have done some wrong connections.
Connected both Optical and SP/DIF from my Philips 963 SA to the same inputs on the DAC.
Peter
Old 20th June 2014, 01:30 PM   #2189
Peter
Hi ..
Please check id display shows "unbal" .. If this is the case then, set the output to "bal" (for balanced output of the DAC chip) .
You can do this by pushing the +S and -S on the front panel at the same time..
Br
Caad
Old 20th June 2014, 04:18 PM   #2190
Hi
I really did not know or guess the use of +S/-S to be pushed at the same time.
Do you have any other secrets about this remote/DAC?
Any page or Forum where you describe the best use ?
Peter
DAC-END R (ES9018) full assembled boardHide this!Advertise here!
DAC-END R (ES9018) quanghao Digital Source 168 22nd June 2013 01:13 PM
DAC ES9018 Evaluation Board / No Output ghmfranken Digital Line Level 7 15th January 2013 09:13 PM
FS: NeoY2ks ES9018 DAC board with all the components guglielmope Swap Meet 4 18th December 2012 11:01 AM
Another DIY ESS ES9018 Sabre DAC board Trevor White Digital Line Level 4 19th August 2010 03:41 PM
Copyright ©1999-2017 diyAudio
