Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 11th July 2013, 10:37 PM   #1111
randytsuch is offline randytsuch
In a somewhat SPDIF related question, how are you guys generating 192k data?
My macbook only goes to 96k. For the higher data rates, I am using the USB and amanerro.
I thought the touch only goes to 96k?
And to me, USB to SPDIF doesn't make sense, unless you didn't buy the amanerro module.
Randy
My system is here
http://randytsuch-audio.blogspot.com/2005/10/my-system.html
Old 11th July 2013, 10:43 PM   #1112
caad is offline caad  Denmark
Randy
Hi randy.
The squeezebox touch has a plug in that can make it play 192khz /24bit files
I have tested this via the coax output.
Br
Caad
Old 12th July 2013, 12:38 AM   #1113
quanghao is offline quanghao  Viet Nam
DAC-END R (ES9018) full assembled board Send a message via Yahoo to quanghao DAC-END R (ES9018) full assembled board
Hi TarnishedEars!
You want to ask this 4 pin connector?
I will send you 4-wire with shield?
And here's how it's connected, offers you view pictures!
Old 12th July 2013, 12:45 AM   #1114
Originally Posted by Domi_78 View Post
Hi Halook,
Here is close up of the spdif section of my board.
- On mine, R68 is installed but this part of the circuit does not concern the coaxial input.
R68 is not part of the in put.
It's distributed R DAC chip set - ** Although this code worked, but still need to keep this resistor **, I welded it for your self the 2nd post. The first time you send is not it.
You should keep it. If not please help me weld it, or worth 3.3k Ohm 3.3K Ohm (SMD 1206). No need resistors good.
Thank you all!
Old 12th July 2013, 12:50 AM   #1115
Originally Posted by TarnishedEars View Post
However I would also like to try the DAC with a tube output stage, as well as a transformer output (among other things). But I need to find some more of those 4-pin connectors to be able to do this without soldering to the main-board.
Thanks again!
if you use the output tube, you should use mode I / out of the DAC, and 4 resistors change IV: R71, 73, 74, 77 - to get the desired gain
Old 12th July 2013, 12:58 AM   #1116
Hi Andrea,
- What are the results of your tests on prototype ?
C36 will leave capacitors bypass the limitations of quality capacitors. Because Andrea and I started to use the number of variables, so we can be rid of this capacitor.
You can test the value of C36 from 0.1uF to 10 uF.
thank you!
Old 12th July 2013, 07:37 AM   #1117
masterkey is offline masterkey  Europe
Hello Quanghao,
Do you have an estimate when you can send the completed DAC?
I completed my payment, please update the list of Group Bay.
Thank you.
Old 12th July 2013, 08:00 AM   #1118
Originally Posted by masterkey View Post
Hello Quanghao,
Thank you.
ok, i seen!
thanks
Old 12th July 2013, 08:01 AM   #1119
TarnishedEars is offline TarnishedEars  United States
Originally Posted by quanghao View Post
Hi TarnishedEars!
Yes, please do send me some of those connectors with the shield. And let me know how much money I will owe you for these. I'd like to order 8 extra connectors so that I can try a bunch of different output topologies on my DAC.
And thank-you for the diagram! That will be very helpful.
Old 12th July 2013, 02:54 PM   #1120
[QUOTE=TarnishedEars;3558542]Yes, please do send me some of those connectors with the shield. And let me know how much money I will owe you for these. I'd like to order 8 extra connectors so that I can try a bunch of different output topologies on my DAC.
I do not take your money, please consider it my gift. And I just want you to complete DAC!
ok,i sent to you 10 connectors. And I not get your money, only monye for shipping !
All 10$!
thanks!
DAC-END R (ES9018) full assembled boardHide this!Advertise here!
DAC-END R (ES9018) quanghao Digital Source 168 22nd June 2013 01:13 PM
DAC ES9018 Evaluation Board / No Output ghmfranken Digital Line Level 7 15th January 2013 09:13 PM
FS: NeoY2ks ES9018 DAC board with all the components guglielmope Swap Meet 4 18th December 2012 11:01 AM
Another DIY ESS ES9018 Sabre DAC board Trevor White Digital Line Level 4 19th August 2010 03:41 PM
