DAC-END R (ES9018) full assembled board - Page 49 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Quanghao Audio Design
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 13th May 2013, 08:00 PM   #481
asdiasx is offline asdiasx  Brazil
asdiasx's Avatar
Send a message via MSN to asdiasx
Hi, is it still possible to participate of this GB?
I saw people paying 50%, when is the second hlaf due?
Adriano Dias
Old 13th May 2013, 08:03 PM   #482
Miclaud is offline Miclaud  Italy
Originally Posted by danny_66 View Post
Yes, there's even a 50 page thread for it.
Thank you very much, I'm pretty new here and I didn't noticed the thread. I'm gonna read it ;-)
Old 14th May 2013, 01:17 PM   #483
Originally Posted by caad View Post
Hi
According to Audiodesignguide the Shunt regulators can deliver 60mA.
Each Burson HD opamp (single module) drawes 19mA according the Burson Website.
You will need 2pcs dual opamp modules : 4*19mA = 76mA..
and AD797?
Old 14th May 2013, 11:18 PM   #484
The AD797 is probably not so good in this circuit. See post 7 in this thread for example.
AD797 now sounds like it should
Old 15th May 2013, 03:27 AM   #485
Default Suitable transformer
I need to ask some advice from other participants on this list, please. I'm part-paid for:
- DAC base (without opamp I/V stage)
- Chassis
- Transformer
But I now realise it's wrong for me to use quanghao's transformer, since my own I/V stage (FET based) will require different AC voltage and higher current rating. So for the DAC base I should just buy my own 0-9VAC x2 transformer, right?
Is this 30W R-core transformer OK -
30W 220V R Core Transformer Output 9V 9V | eBay
The two secondary windings are rated at 1.7A each.
or there's a more expensive version here which is claimed to have "steel coiled silicon steel sheet and oxygen-free copper enamel wire" -
220V 30W High Quality R Core Transformer 9V 9V | eBay
Thanks.
Old 15th May 2013, 01:15 PM   #486
Boxi80 is offline Boxi80  Italy
Any news about the estimated time for completing the boards and shipping?
Old 15th May 2013, 02:13 PM   #487
- Chassis
- Transformer
Thanks.
At some point, the transformer for the dac was specified as 6-9V, 1A x 2, so the tx's you picked would work.
However, for my tx, I will probably look for something closer to 6V, instead of at the 9V end. At 9 VAC in, the DAC will need to dissipate more power to regulated down to the proper voltages. More power is more heat, which tends to shorten the life of parts.
So it will work, but not what I would use.
Randy
My system is here
http://randytsuch-audio.blogspot.com/2005/10/my-system.html
Old 16th May 2013, 03:47 AM   #488
Thanks Randy. 9V seems to be the minimum value available for an R-core, so I guess I will use a toroid - an encapsulated 30W toroid, at 0-6Vx2 or 0-7.5Vx2.
Old 16th May 2013, 03:57 AM   #489
Send a message via Yahoo to quanghao Send a message via Skype™ to quanghao
no!
only 0- 6VAC/ 1.5A x 2, not can use 9V for this DAC!
and 18-0-18 / 200mA min
thanks
Old 16th May 2013, 04:37 AM   #490
Thanks quanghao,
So I will use this 30W encapsulated toroid - 0-6VACx2 (2.5A x2)
Altronics - M4612 6 + 6V PCB 30VA Toroidal Transformer
If it's OK, please delete transformer from my order. According to the latest order list (post #372) -
16. 1 x linuxfan ( DAC base + DAC chassis + transformer)
should now be -
16. 1 x linuxfan ( DAC base + DAC chassis)
DAC-END R (ES9018) quanghao Digital Source 168 22nd June 2013 01:13 PM
DAC ES9018 Evaluation Board / No Output ghmfranken Digital Line Level 7 15th January 2013 09:13 PM
FS: NeoY2ks ES9018 DAC board with all the components guglielmope Swap Meet 4 18th December 2012 11:01 AM
Another DIY ESS ES9018 Sabre DAC board Trevor White Digital Line Level 4 19th August 2010 03:41 PM
Copyright 1999-2017 diyAudio
