DAC-END R (ES9018) full assembled board - Page 190 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Quanghao Audio Design
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 14th October 2013, 07:25 PM   #1891
Originally Posted by audiodesign View Post
Which is your source ?
RME HDSP9632 pci cardbus
Old 15th October 2013, 01:10 AM   #1892
i2k92 is offline i2k92  Indonesia
You can set the startup Volume, see guide
It's OK now, thank you. BTW, I have a strange problem. Whenever I use the remote for my air conditioner, the DAC output become distorted with lots of pops which I'm afraid could break the speaker. The solution is very simple, turn on AC before the DAC perhaps I need to upgrade my AC into audiophile grade AC hahaha
After 12 hours, the sound is getting better.
Old 15th October 2013, 05:11 AM   #1893
Banned
Send a message via MSN to audiodesign Send a message via Skype™ to audiodesign
Originally Posted by misterwolf View Post
yes, I tried now this solution, locked until 96khz.
Andrea,
after many hours spent in the last few days to try out the various solutions, that's enough.
Next Saturday will bring the dac in a recording studio to try the AES / EBU and SPDIF.
I hope to find that electrical inputs of the DAC work fine up to 192kHz.
Also for AES / EBU should be better add the capacitor after the input transformer.
Old 15th October 2013, 07:00 AM   #1894
Banned
Default Guide
The save function store input, filter configuration and volume on PIC non-volatile memory.
Old 15th October 2013, 07:17 AM   #1895
Quanghao... I am looking to build a tuber buffer with a DAC, 32 bit and USB. The tube buffer will be from a supplier in China who is offering their version on the X10d Tube buffer. The one I am looking at is on a red board. The tuber buffer will be in the same case as the DAC but not connected and totally passive. I would like to have a single momentary switch to select SPDIF, Optical and USB inputs with LED displays. I was looking at one supplier that had a USB DAC on a yellow board with 3 LEDs showing USB, Optical and SPDIF on a board connected by a flat cable. Do you have anything like this or what would you recommend. Also I will be driving the buffer and DAC on separate triodial transformers. This is the board I was looking at for the DAC http://www.aliexpress.com/item/Free-...297634764.html. The X10D buffer is this one http://www.aliexpress.com/item/New-v...121382297.html
Merrisa
Old 15th October 2013, 09:48 AM   #1896
danny_66's Avatar
Hi Merrisa,
For a tube buffer I would rather use an ACF2.
My RefSpeaker
Old 15th October 2013, 12:37 PM   #1897
Banned
Originally Posted by Merrisasjc View Post
Quanghao... I am looking to build a tuber buffer with a DAC, 32 bit and USB. The tube buffer will be from a supplier in China who is offering their version on the X10d Tube buffer. The one I am looking at is on a red board. The tuber buffer will be in the same case as the DAC but not connected and totally passive. I would like to have a single momentary switch to select SPDIF, Optical and USB inputs with LED displays. I was looking at one supplier that had a USB DAC on a yellow board with 3 LEDs showing USB, Optical and SPDIF on a board connected by a flat cable. Do you have anything like this or what would you recommend. Also I will be driving the buffer and DAC on separate triodial transformers. This is the board I was looking at for the DAC Free Shipping! 1pc 24bit192K CS8416 + parallel dual WM8741 * 2 DAC decoder finished board usb input-in Other Electronic Components from Electronic Components & Supplies on Aliexpress.com. The X10D buffer is this one New version X 10D preamplifier kit (include 2 X 6N11 tubes)-in Integrated Circuits from Consumer Electronics on Aliexpress.com
Merrisa
The ES9018 DAC chip for each channel have a differential output so it is necessary a differential stage to create an un-balanced output to connect to your vacuum tube buffer.
You could use a single op-amp like show in my post #1859.
If you want to use a pure vacuum tube differential stage see my design on:
ES9018 USB DAC - Hi-Resolution System*
No problem to switch the 3 spdif sources (coax, toslink and aes/ebu) with a relay and led.
Old 15th October 2013, 01:22 PM   #1898
Banned
Originally Posted by danny_66 View Post
Hi Merrisa,
Also this need a differential stage to get un-balanced output
Old 15th October 2013, 01:28 PM   #1899
danny_66's Avatar
True, I was thinking as a tube buffer for behind the LL1684 transformer.
ES9018 balanced -> LL1684 single ended -> ACF2 single ended
My RefSpeaker
Old 15th October 2013, 07:18 PM   #1900
I think I have caused some confusion.... I want the tube buffer to be a completely unconnected circuit to the dac. The buffer and dac will share the same case but have separate input and out puts. Only the pre out of the amp and main in on the amp will be connected to the buffer.
The DAC will only be connected to the Aux of the amp and whatever source I connect to it.
Basically stand alone circuits just sharing the same chassis. Both will have their own transformers and power supplies as well.
DAC-END R (ES9018) quanghao Digital Source 168 22nd June 2013 12:13 PM
DAC ES9018 Evaluation Board / No Output ghmfranken Digital Line Level 7 15th January 2013 08:13 PM
FS: NeoY2ks ES9018 DAC board with all the components guglielmope Swap Meet 4 18th December 2012 10:01 AM
Another DIY ESS ES9018 Sabre DAC board Trevor White Digital Line Level 4 19th August 2010 02:41 PM
Copyright 1999-2017 diyAudio
