Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 12th December 2011, 06:24 AM   #1
quanghao is offline quanghao  Viet Nam
The best preamplifier Send a message via Yahoo to quanghao The best preamplifier
Default The best preamplifier
Hi All
This is a design I did in 5 years!
It has been many favorite friend. Especially in 2011 I have improved dramatically! To me this is my best pre tube using 6H30Pi or 6Dj8 ...
I opened the topic here, because this is the place to discuss all matters of Audio uses tube!
Sounds very realistic detail, balance!
Old 12th December 2011, 09:25 AM   #2
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
Hello Quanghao,
whats the bias and why is the gain so high for a linestage? I thought you said somewhere it was less than unity gain?
If you give a man a fish he will eat for a day. But if you teach a man to fish he will buy an ugly hat. And if you talk about fish to a starving man then you are a consultant. Dilbert
Old 12th December 2011, 10:17 AM   #3
DF96 is offline DF96  England
Miller effect? It would need to be driven from a low impedance source, otherwise some HF cut is likely - it could sound smooth (i.e. inaccurate).
Old 12th December 2011, 10:24 AM   #4
On Hiatus
SY's Avatar
Presumably, it will have a level control, which will allow the sound to change spectral balance at different volume settings.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 12th December 2011, 10:38 AM   #5
suntechnik is offline suntechnik  Russian Federation
Actually tubes input capacitance is less than most semi-insulators especially if talking about something like FE86 or KT88.
However personally I would prefer mu-followers for triodes like 6N6P -30P, 6DJ8
Old 12th December 2011, 11:27 AM   #6
Yes!
This cap Miller = 10pF!
Output impedance about 500R
Old 12th December 2011, 11:37 AM   #7
Originally Posted by Luke View Post
Hello Quanghao,
+ B= 160V
One Tube = 17.5 mA
One channel need ~35mA
Old 12th December 2011, 11:40 AM   #8
On Hiatus
SY's Avatar
Originally Posted by quanghao View Post
Yes!
How do you arrive at that number? From the datasheet values, one would expect about 12-15 times higher.
Old 12th December 2011, 11:42 AM   #9
Hi!
By practical experience!
I practice many times and found that the best results!
Old 12th December 2011, 11:52 AM   #10
On Hiatus
SY's Avatar
OK, so no measurement or calculation, just assertion from the seller.
Using a more conventional engineering approach, one should expect 120-150pF, maybe somewhat more, depending on strays from wiring (which can be considerable with four paralleled sections) and how optimistic the datasheets are.
The best preamplifierHide this!Advertise here!
preamplifier Giorgos3924 Tubes / Valves 15 8th April 2012 12:27 AM
My new Preamplifier kawo Vendor's Bazaar 21 24th August 2010 05:17 PM
Why do you need a preamplifier? globalweb Solid State 54 14th October 2007 04:47 PM
Preamplifier aguantesoda Solid State 24 8th September 2006 02:39 PM
help with preamplifier skobo Solid State 9 15th July 2005 12:54 PM
