The best preamplifier - Page 3 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Quanghao Audio Design
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 12th December 2011, 04:34 PM   #21
kevinkr's Avatar
Originally Posted by artosalo View Post
I looked carelessly at the schematic and did not notice the added capacitor from the grid to anode.
But I could not find that there would be 4 tube halves ( 2 x 6N30P) in parallel.
Is it really so ?
Dual triode and the schematic seems to indicate two tubes, each pin has two pin numbers associated - presumably this means there are 4 sections in parallel. I'm not sure, language and drawing issues confuse the matter.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 13th December 2011, 01:42 AM   #22
Charm is offline Charm  Russian Federation
http://klausmobile.narod.ru/td/data/_6n6p.GIF
Tube Tester Files - 6N6P - 6H9?
Old 13th December 2011, 11:04 AM   #23
Sorry Tube Tester Files - 6N30P - 6H30Ï
http://www.etd.su/djvu/209/1/6n30p-dr.djvu
Old 13th December 2011, 11:44 AM   #24
Alain Poitras's Avatar
Originally Posted by Yvesm View Post
Almost !
You've just forgoten the "magical" deliberatly added 10pF that makes this preamp "the best"
Here is "The Better Preamplifier Of The Whole Know And Unknow Universe" :
Yves.
Faux ... La réponse est perturbée par l'inductance, la capacité et la résistance du câble coaxial utilisé entre l'entrée et la sortie ... Sans parler de l'absence d'adaptation d'impédance et de gain qui sont les raisons d'être d'un préamplificateur !
Alain.
P.S. I like very much your tubes curves tracer design using the powerline sinewave and the sound card inputs for the voltage and current simultaneous reading ... You are a "pro" !
Old 13th December 2011, 02:09 PM   #25
DF96 is offline DF96  England
Sorry, my mistake. I must have counted grid connections instead of grids!
Your preamplifier will sound harsh and clinical, even though it will measure almost perfectly.
Old 13th December 2011, 04:05 PM   #26
Ah ah Alain,
You were quicker than me
greg
Old 13th December 2011, 04:39 PM   #27
kevinkr's Avatar
It's not really clear to me whether it uses 1 x 6N30 or 2 x 6N30, the tube is a dual and the schematic implies to me based on the pin# shown that there are in fact 4 triode sections in parallel.
Yves, I love the last line in your copyright statement..
Old 14th December 2011, 02:11 AM   #28
Send a message via Yahoo to quanghao Send a message via Skype™ to quanghao
I like your say: *Your preamplifier will sound harsh and clinical, even though it will measure almost perfectly*
thanks
Old 14th December 2011, 03:08 AM   #29
AJT is offline AJT  Philippines
AJT's Avatar
hi quangho, mind sharing your rationale for paralleled tube sections? have you tried the 6080 at such levels of voltage and currents?
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 14th December 2011, 04:40 AM   #30
Ok!
that is circuit of my PRE
preamplifier Giorgos3924 Tubes / Valves 15 8th April 2012 12:27 AM
My new Preamplifier kawo Vendor's Bazaar 21 24th August 2010 05:17 PM
Why do you need a preamplifier? globalweb Solid State 54 14th October 2007 04:47 PM
Preamplifier aguantesoda Solid State 24 8th September 2006 02:39 PM
help with preamplifier skobo Solid State 9 15th July 2005 12:54 PM
Copyright ©1999-2017 diyAudio
