DAC-END The best DAC AD1865- UPDAT 2011 - Page 3 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Quanghao Audio Design
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 13th May 2011, 02:28 PM   #21
Send a message via Yahoo to quanghao Send a message via Skype™ to quanghao
Originally Posted by mines View Post
Hi quanghao,
When the kit ready?
hi!
Some times, i finis all!
Old 13th May 2011, 06:25 PM   #22
Originally Posted by quanghao View Post
In this PCB-DAC I use other Shunt regulator, design by Hqaudio!
please see it!
thanks
Seems that salas's low shunt is well design with good result, can you comment any improvements for this over salas one?
Old 20th May 2011, 03:28 AM   #23
Salas V1 very good and great for the DAC, but with DIY, the research findings are not keep your stop! Therefore, design and finishing is my job to be done! Thanks!
Old 20th May 2011, 02:14 PM   #24
mkanna is offline mkanna  United States
Default Audio Note Dac?
I found this on the audiodesign guide site, as I was reading throught the "AD1865 the best DAC thread, where Mr. Ciufoli is experimenting to come up with optimal I/V conversion:
"Follows the measurement of the DAC board on AD1865 output with a filter composed by a 100uH choke and 10nF capacitor in parallel to the 200ohm resistor (like the AudioNote DAC), the sampling frequency 44KHz is at -35dB."
I couldn't attach measurements (don't know how), and they are not relavant to my questions, anyway. Isn't this making the chip work very hard, slowing it down? Another question, which AudioNote dac uses this method?
mkanna
Old 9th June 2011, 01:11 PM   #25
hotzman is offline hotzman  Romania
Hi Quanghao,
Please tell me if the new DAC-END The best DAC AD1865- UPDAT 2011 pcb is already available for sale?
I am interested to buy two pieces!
Thank you!
Old 9th June 2011, 03:00 PM   #26
Originally Posted by hotzman View Post
Hi Quanghao,
Thank you!
yes! this is PCB DAC-END updat 2011
Old 10th June 2011, 10:32 PM   #27
Kuka is offline Kuka  Germany
is it possible to combine the last DAC-ASH IVstage with new DAC-END AD1865 board? I think this should be no problem, isn't it?
Old 10th June 2011, 11:42 PM   #28
it is good, no problem!
Old 11th June 2011, 04:53 AM   #29
NG is offline NG  Hong Kong
Hi Quanghao:
Great that you are doing a pcb for the AD 1865. Myself I have built the TDA 1541A parallel DAC + 6P45C from scratch with the information provided by diyers from the net. Thanks to them once again.
Like you have said, I think audiophiles never really stop searching for something better. That is why I would like to build your AD 1865 and compare with my TDA 1541A together with my newly build 26 preamp.
Could you tell me what you can provide ? Only the pcb boards ? A kit ?
Has the boards been fully tested ?
Thanks in advance !
Best regards,
NG
Old 11th June 2011, 12:09 PM   #30
Hi Quanghoa,
Between output of DAC-END AD1865 and DAC-ASH I like to use Sowter 9762 transformers like Audio Note DAC 3.1 kit! I saw somewhere implement this option for 5687tubes. Can you upload again the schematic?
How do you buy the two sets of PCBs (2 X new DAC-END The best DAC AD1865- UPDAT 2011 and 2 x DAC-ASH IVstage)?
Send me a PM!
Thanks!
AD1865 the best DAC audiodesign Digital Source 352 17th November 2013 04:08 PM
DAC-ASH (dac-end 2 up date) quanghao Quanghao Audio Design 494 24th July 2012 12:20 AM
Dac End Boards and 1865 DAC chip boudy Swap Meet 2 30th April 2011 01:23 PM
Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! sharpi31 Digital Line Level 2 10th January 2011 07:03 AM
My DAC on AD1865 waldez Digital Line Level 1 21st April 2009 01:38 AM
Copyright 1999-2017 diyAudio
