DAC-END The best DAC AD1865- UPDAT 2011 - Page 20 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Quanghao Audio Design
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 2nd July 2013, 10:30 AM   #191
fsrjd3 is offline fsrjd3  Ireland
Default Dac End
Iíve just completed a comparison of the your Dac End and the dCS setup. I had Russian Teflon output capacitors and Jensen in Dac End and had it set up so I could switch between them. They were very similar but I think I preferred the Jensen. The other listener preferred the Russian Teflon caps.
The The dCS Verdi transport was used for both tests.
Again the sound of the dCS with Verona Master clock and Purcell Upsampler and Elgar Dac was indistinguishable from the Dac End. I may have preferred the dCS setup but the other listener preferred the Dac End. I would not have been able to pick one over the other in a blind AB comparison
The dCS setup is made in the UK but was Stereophile no 1 rated digital component for a number of years and according to them sold as new for $41000. It was superceded by later and more expensive dCS products.
Neither system sounded as good as my vinyl so even when you pay $41,000 a much less expensive vinyl setup will sound better.
I expect I will now sell my dCS system and keep the Dac End. Hopefully anyone reading this review will not be a prospective buyer.
I did the comparison using Stax headphones rather than amps and speakers as I think they are more detailed,
I would like do do a comparison using the Lundahl LL1660AM amopphous core output transformers. I would be curious to see if the Dac End would then outperform the dCS
Ronan Daly
Old 25th September 2013, 08:45 AM   #192
Send a message via Yahoo to quanghao Send a message via Skype™ to quanghao
Ronan Daly
thanks
Old 19th August 2014, 11:05 PM   #193
Algar_emi's Avatar
I just bought an AD1865 Dac-End3 kit from an other user. It is almost all assembled, configured for the 6H30 tube.
One question, Do I still need to install the 120uH inductor at the dac output, or I can feed the dac directly into the Tueb IV stage, keeping the Caddock IV resistor on the DAC PCB naturally.
Any help appreciated. Thanks.
Old 20th August 2014, 06:14 AM   #194
Hi, Algar!
Here you can find the basic circuitry: http://audiodesignguide.com/DACend2/index.html
With your I/V stage inductors should be soldered in.
Daniil
Old 20th August 2014, 07:38 AM   #195
Ryssen is online now Ryssen  Sweden
Ryssen's Avatar
Anyone have a Digikey number for the 10w Heatsinks used on the I/V board?
Regards Ňke
Old 20th August 2014, 07:59 AM   #196
rol is offline rol
This is the one used in I/V:
Invalid Request
Old 20th August 2014, 10:05 AM   #197
Ryssen's Avatar
Thanks!
Regards Ňke
Old 21st August 2014, 02:39 AM   #198
Algar_emi's Avatar
These are the ones on mine, from Mouser: 588-FA-T220-51E
Thanks danielkol but my pcb are the latest version, DAC and Tube IV date 31/5/2011. The DAC shunt and DAC layout are different. The IV PCB layout is different as well. I have the correct schematics, but not the exact pcb silkscreen. I should be ok. I was just wondering about these inductors. I'll post my complete Excel parts file if anyone interested, it is kind of an old thread.
Old 21st August 2014, 12:47 PM   #199
frd__ is offline frd__  Poland
Try both options: without and with the inductors and decide which one sounds better to your ears. I remember I was trying that for a number of weeks until I finally decided do stay with the inductors.
Old 21st August 2014, 11:11 PM   #200
Algar_emi's Avatar
I will, here my Parts List
AD1865 the best DAC audiodesign Digital Source 352 17th November 2013 04:08 PM
DAC-ASH (dac-end 2 up date) quanghao Quanghao Audio Design 494 24th July 2012 12:20 AM
Dac End Boards and 1865 DAC chip boudy Swap Meet 2 30th April 2011 01:23 PM
Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! sharpi31 Digital Line Level 2 10th January 2011 07:03 AM
My DAC on AD1865 waldez Digital Line Level 1 21st April 2009 01:38 AM
Copyright ©1999-2017 diyAudio
