| Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests! |
#171 |
Andrea _mori
don't install TORX the Torx and the XLR Balanced are connected in parallel to the relay |
#172 |
Thanks Quanghao, the dac board arrived. Best, John
#173 |
hi Quanghao, I have not found schematic for your stage iv board, this is one dated 15/9/2011 and has lots of diodes on it which are not speficied. as well as 4 jumper wires.
Can you kindly post a scheuatic for this sshu LL1660 iv stage board. thanks, John |
#174 |
Just finished, to be tested
#175 | |
jum 6H if you use tube 6Dj8, 6h30 Jum 5687 for 5687 and el82cc, or bandix 6900 thank
Group buy DAC-END R (ES9018) full assembled board update 8/5/2013 : https://docs.google.com/spreadsheet/...2c&hl=en#gid=0 |
#176 |
#177 |
The Mullard E182CC sounds better, more warm and equilibrated. The JAN 5687 sounds a little cold, but more detailed.
The Mullard are very very microphonics. |
#178 |
Hi.Quanghao, the last 2 months, pcb has not received? Thanks.
#179 |
Hi! Quanghao, pcb received, thanks.
#180 |
Hi all! Who bought the components here, the original?
CS8414 CS8414CS CS8414 CS 96K Digital Audio Receiver Soldered on DIP Adapter | eBay 1pcs AD1865 AD1865N AD1865N K Dual 18bit 16XFS DAC DIP 24 Adi Brand New | eBay |
| AD1865 the best DAC | audiodesign | Digital Source | 351 | 21st April 2013 07:19 PM |
| DAC-ASH (dac-end 2 up date) | quanghao | Quanghao Audio Design | 494 | 24th July 2012 12:20 AM |
| Dac End Boards and 1865 DAC chip | boudy | Swap Meet | 2 | 30th April 2011 01:23 PM |
| Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! | sharpi31 | Digital Line Level | 2 | 10th January 2011 07:03 AM |
| My DAC on AD1865 | waldez | Digital Line Level | 1 | 21st April 2009 01:38 AM |
