DAC-END The best DAC AD1865- UPDAT 2011 - Page 17 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Quanghao Audio Design
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 29th November 2012, 02:20 AM   #161
Send a message via Yahoo to quanghao Send a message via Skype™ to quanghao
Originally Posted by hordmop View Post
Hi Quanghao, I have a problem with the power stage circuit in the 260V SSHV specifically, since there is only the 61V output.
I have attached some pictures where you can see the component values ​​that have been used and the voltages obtained.
Thanks.
please change new IRF 9610 and 3 led.
measure the V on R1 = 1.8 to 2.1v, it is good!
thanks
Old 29th November 2012, 07:57 PM   #162
hordmop is offline hordmop  Spain
Hi Quanghao,
I changed the IRF9610 and the 3 LEDs with a new one.
I measured the voltage on R1 33ohm = 18V.
I have two PCB mounted and the problem is the same in both.
Only 82 V at the output.
What is the correct value to R12 and R4? in Scheme R12 = 270K (1W) R4 = 120K (2W). R12 on the PCB is R8 = 220K (1W) R4 = 180K (2W).
R3 56K in Scheme (5W) PCB (R3 = 180K, R3B = 180K, R3C = 180) Total = 60K.
For 56K (R3 = 180K, R3B = 180K, R3C = 150K) Total = 56K250.
Have you tried the new PCB? I do not understand where the problem is.
Thanks.
Old 1st December 2012, 01:13 PM   #163
hello Quanghao,
I think I found the problem resistor R1 = 33 Ohm, in the two PCBs were cut could not imagine that 2 of 33 ohm resistors Dale new were defective.
On Monday I will see if it works well now I have 33 Ohm resistors. Sorry I bothered by this problem.
Thank you.
Old 1st December 2012, 08:04 PM   #164
hello Quanghao,
Thank you.
Hi how it work??
thank
Old 2nd December 2012, 05:00 PM   #165
andrea_mori's Avatar
Quanghao, guys,
my transport provides a balanced output, so I would like to use DAC END XLR input.
Did you test XLR input? Does balanced connection works?
Thanks all
Andrea
Old 3rd December 2012, 08:14 AM   #166
Default Balanced input
Anyone can help?
Andrea
Old 4th December 2012, 08:32 PM   #167
Originally Posted by andrea_mori View Post
Quanghao, guys,
Thanks all
Andrea
yes, but you not use toslink.
thanks
Old 4th December 2012, 08:55 PM   #168
hello Guanghao,
the sound is very nice and fairly compensated, thanks to Andrea, and to you for the work you have done.
Just one more question I have installed the 5687 and point B I have 144V. and point P 51V. is that correct?.
without putting the Tubes I have in the point B 260V.
thanks
Old 4th December 2012, 09:11 PM   #169
hello Guanghao,
thanks
no!
if not use LL1660 out put,
So the V at +B 250 to 260V, The vol at Anode at 90 to 100V. thanks
Old 4th December 2012, 10:16 PM   #170
thanks
do you mean don't use both at the same time?
or don't install TORX?
Andrea
AD1865 the best DAC audiodesign Digital Source 352 17th November 2013 04:08 PM
DAC-ASH (dac-end 2 up date) quanghao Quanghao Audio Design 494 24th July 2012 12:20 AM
Dac End Boards and 1865 DAC chip boudy Swap Meet 2 30th April 2011 01:23 PM
Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! sharpi31 Digital Line Level 2 10th January 2011 07:03 AM
My DAC on AD1865 waldez Digital Line Level 1 21st April 2009 01:38 AM
Copyright 1999-2017 diyAudio
