DAC-END The best DAC AD1865- UPDAT 2011 DAC-END The best DAC AD1865- UPDAT 2011 - Page 16 - diyAudio
Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 5th November 2012, 08:34 AM   #151
quanghao is offline quanghao  Viet Nam
DAC-END The best DAC AD1865- UPDAT 2011 Send a message via Yahoo to quanghao DAC-END The best DAC AD1865- UPDAT 2011
Originally Posted by andrea_mori View Post
Hi Quanghao,
0-220Vac does not exist, HV secondaries of R80-36 are 260-230-0-230-260, do you mean 0-230 in parallel full wave rectified (230Vac * 1.414 = about 325 Vcc)?
Andrea
use 230-0-230, and use 2 diode in put!
thanks
Old 5th November 2012, 08:51 AM   #152
andrea_mori is offline andrea_mori  Italy
andrea_mori's Avatar
thanks
Thanks for reply,
but I have a doubt, why a center-tapped two-diode rectifiers instead of paralleling 0-230 secondaries and using a full wave with 4 diodes rectifiers?
What's the advantage?
Also on the PCB there are places for 4 diodes rectifiers.
Andrea
Old 5th November 2012, 09:55 AM   #153
Thanks for reply,
Andrea
yes
Old 9th November 2012, 07:34 AM   #154
ua3grn is offline ua3grn  Russian Federation
quanghao, you send pcb?
Old 10th November 2012, 02:56 PM   #155
yes!
thanks
Old 13th November 2012, 05:20 PM   #156
JohnGeneva is offline JohnGeneva  Switzerland
Hi Quanghao, Wanted to make sure you received payment for Dac pcb. did you already send the PCB? thanks, John
Old 21st November 2012, 08:03 AM   #157
Hi all!
To day i have some PCB IV LL1660 , if you like please sen to me pm!
Old 21st November 2012, 08:10 AM   #158
Hi andrea_mori !
Did you finis your DAC??
what i can hepl you more??
thanks
Old 21st November 2012, 08:50 AM   #159
Hi andrea_mori !
thanks
not yet, I'm busy on other project.
Question: I would like to use xlr balanced input, since my transport provides this output, did you test xlr input? does it work correctly?
Andrea
Old 28th November 2012, 07:38 PM   #160
hordmop is offline hordmop  Spain
Default Problem with the power stage circuit
Hi Quanghao, I have a problem with the power stage circuit in the 260V SSHV specifically, since there is only the 61V output.
I have attached some pictures where you can see the component values ​​that have been used and the voltages obtained.
Thanks.
DAC-END The best DAC AD1865- UPDAT 2011Hide this!Advertise here!
AD1865 the best DAC audiodesign Digital Source 352 17th November 2013 04:08 PM
DAC-ASH (dac-end 2 up date) quanghao Quanghao Audio Design 494 24th July 2012 12:20 AM
Dac End Boards and 1865 DAC chip boudy Swap Meet 2 30th April 2011 01:23 PM
Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! sharpi31 Digital Line Level 2 10th January 2011 07:03 AM
My DAC on AD1865 waldez Digital Line Level 1 21st April 2009 01:38 AM
Copyright ©1999-2017 diyAudio
