Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 26th October 2012, 04:43 PM   #141
ThuyTN is offline ThuyTN
Send a message via Yahoo to ThuyTN
Originally Posted by andrea_mori View Post
I have just received the last version PCB and I have some difficult to find all parts, because there are some differences from schematic to PCB and BOM. So I have some questions for Quanghao and all guys that built the DAC:
I have just finished the Mouser BOM for myself, basing on the latest PCB's revision. Let me know if you need it
Old 26th October 2012, 05:21 PM   #142
andrea_mori is offline andrea_mori  Italy
andrea_mori's Avatar
DAC-END The best DAC AD1865- UPDAT 2011
I also prepared a BOM with parts from Mouser/Parts Connexion and eBay and I'll post it for other diyers.
Could you post your BOM, so we can compare with mine to produce the final BOM?
Andrea
Old 27th October 2012, 07:33 AM   #143
Yeah, sure. Mine is attached.
There are some missing parts because I've already have them in the parts bin so I just left them out from the BOM.
Also, I overspec'd some caps, increased the quantity of some easy-to-fail (2sk170, bc550, bc560, mje350, irf9510...) parts to have some backups in case something goes wrong during the build.
Old 27th October 2012, 03:40 PM   #144
I attach my BOM, all parts except for the case, from Mouser, Parts Connexion and eBay.
A few questions:
- did you mount SPDIF transformer?
- about IV HV: are you using centre tapped 260-0-260 and 2 rectifiers only or single 0-260 and 4 rectifiers?
Old 27th October 2012, 04:43 PM   #145
You can skip the spdif transformer if you only use coaxial input.
I use 0-260v transformer and 4 recitifiers. Look for the Aavid 2.5" to-220 heatsinks for best heat dissipating.
Old 28th October 2012, 12:18 AM   #146
Right, I choose a 3.4C/W thermal resistance, but the Aavid heatsink is 2.6C/W.
Old 2nd November 2012, 11:35 AM   #147
Hi all,
I'll use 5687 and E182CC tube, so I have the following questions:
- filament: linking J1 seems the heaters are powered wih 12.6V, so what secondaries of R80-36 transformer should I use? more simple, what colours?
- anode: using 4 rectifiers and R80-36 transformer, what secondaries should I use 0-230 or 0-260? in parallel? more simple, what colours?
Andrea
Old 4th November 2012, 09:49 AM   #148
Anyone can help me?
Andrea
Old 5th November 2012, 12:26 AM   #149
quanghao is offline quanghao  Viet Nam
DAC-END The best DAC AD1865- UPDAT 2011 Send a message via Yahoo to quanghao DAC-END The best DAC AD1865- UPDAT 2011
Hi all,
Andrea
hi!
if use 5687 or e182cc use 12Vac for filament
use 0-220Vac for shunt!
Old 5th November 2012, 08:11 AM   #150
Originally Posted by quanghao View Post
hi!
Hi Quanghao,
0-220Vac does not exist, HV secondaries of R80-36 are 260-230-0-230-260, do you mean 0-230 in parallel full wave rectified (230Vac * 1.414 = about 325 Vcc)?
Andrea
DAC-END The best DAC AD1865- UPDAT 2011Hide this!Advertise here!
AD1865 the best DAC audiodesign Digital Source 352 17th November 2013 04:08 PM
DAC-ASH (dac-end 2 up date) quanghao Quanghao Audio Design 494 24th July 2012 12:20 AM
Dac End Boards and 1865 DAC chip boudy Swap Meet 2 30th April 2011 01:23 PM
Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! sharpi31 Digital Line Level 2 10th January 2011 07:03 AM
My DAC on AD1865 waldez Digital Line Level 1 21st April 2009 01:38 AM
