DAC-ASH (dac-end 2 up date) - Page 39 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Quanghao Audio Design
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 21st December 2010, 09:18 AM   #381
phrarod is offline phrarod  United States
I used filter network before in my AN dac and it sounded bad. That's why AN bypassed it eventually. I hope that is not the problem with this board
Old 21st December 2010, 09:19 AM   #382
la1209 is offline la1209  Hong Kong
A 330R resistor parallel with a 820pF cap at the output of the AD1865 used in the DAC broad of AN
Old 21st December 2010, 09:21 AM   #383
They used different values over the years but yes
Old 21st December 2010, 09:24 AM   #384
I think the DAC ASH almost the same as the AN's DAC broad but have a better power supply, or you can install a 0.01uF cap parallel with the IV resistor to see if there any help...maybe the designer here know how to do
Old 21st December 2010, 09:26 AM   #385
I think the distortion make with the I/V stage...
Old 21st December 2010, 09:27 AM   #386
Do you have another AD1865 and try?
Old 21st December 2010, 09:35 AM   #387
I think you helped me locate the problem. The 74H is not outputting the right voltage. I just got off a long very frustrating chat with Quanghao.
If there was an issue with the output the sound would be very different. I believe I have to get the 74H working then deal with the output I/V if they present an issue.
Yes, I ordered this board because it is a copy of the AN board but with better power.
What I need to know is this: If both chips blew up what caused them to blow up in this circuit? I have never blown one of these chips. I know both were working fine. When I put them into the board they both measure exactly the same - being off.
I could order more 74H chips but if the board is blowing them up OR if there is an issue with the PCB then there's no need to order more just to blow them up. Maybe something is shorting to ground in that area?
Old 21st December 2010, 09:35 AM   #388
Yes, I tried three AD1865's No change
Old 21st December 2010, 09:35 AM   #389
Send a message via Yahoo to quanghao Send a message via Skype™ to quanghao
you can remove it?? you connect direct to DAC??
you measure: 74HC04
Pin 1=2.57V
Pin 2 = 2.57V
Pin 4= 5
Pin 6 = 5V
Pin 8,10, 12 = 5V
Old 21st December 2010, 09:45 AM   #390
I did remove it once and got the same distortion
I just checked for shorts on the 74H pins. No shorts to ground.
Since the 74H data sheet shows what looks like internal diodes I measured the pins like diodes as shown and the chip measures how a diode would ie readings in only one direction.
So what are the potential areas that would pull down its voltage aside from short to ground which I don't measure?
diyclub.biz DAC-38, DAC-60, DAC-68. Anybody heard? TonyDasilva Digital Line Level 21 13th April 2009 06:10 PM
Jambo DAC - DIY USB/Optical/Coaxial DAC kit now available! Jambo Digital Source 8 20th August 2008 10:41 AM
Repairing Black Ash veneer BarakaBloke Multi-Way 22 2nd March 2008 06:39 PM
DPA little bit dac modding (7350 dac, ym3623b receiver) ash_dac Digital Source 16 5th December 2007 08:09 PM
FS: Unfinished ash baffles from my OB project - $25 - Seattle, WA area owdi Swap Meet 5 26th July 2007 09:54 PM
Copyright 1999-2017 diyAudio
