DAC-ASH (dac-end 2 up date) - Page 38 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Quanghao Audio Design
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 21st December 2010, 07:19 AM   #371
Send a message via Yahoo to quanghao Send a message via Skype™ to quanghao
Originally Posted by phrarod View Post
It appears 2,4,6,8,10,12 are all output and mine is only outputting correctly on 4, 10. So if the chip is getting 5v on the input pin 14 which I am getting then is all the rest internal? Or does it rely on getting those voltages from somewhere else?
I just did a continuity check on that chip holder and doesn't matter it was oriented wrong since I put the chip in the right way all the pins go to the proper places.
In the image, it is no wrong!
Old 21st December 2010, 07:20 AM   #372
phrarod is offline phrarod  United States
Yes as I said. The chip is in the right way but the notch in the holder is facing the wrong way. I never put the chip in backwards. The issue is the voltage outputs of that chip.
Looking at my voltages what is your opinion of the problem?
Old 21st December 2010, 07:27 AM   #373
Whit Salas low shunt , not worry about it!
You se it not work good??
Old 21st December 2010, 07:49 AM   #374
la1209 is offline la1209  Hong Kong
It seems you haven't installed all the 0.1uF de-couple cap, right?
Old 21st December 2010, 07:51 AM   #375
They are underneath the board
Old 21st December 2010, 08:05 AM   #376
OK, do you check if there any point shorted to GND?
Your DAC now not work? Can't lock SPDIF or what?
Old 21st December 2010, 08:06 AM   #377
Output is 90% distortion. 10% music
Old 21st December 2010, 08:11 AM   #378
OMG!
You now use a pair of Jensen Trans act as Current to Voltage right?
Old 21st December 2010, 08:14 AM   #379
yes, as I have used in that position for 6 years. No problem.
Old 21st December 2010, 08:15 AM   #380
Or you needed to install the filter network to make the output of AD1865 more stable, some guys in China clone the AN DAC before and face same problem too, after they add the filter network, the problem solved
diyclub.biz DAC-38, DAC-60, DAC-68. Anybody heard? TonyDasilva Digital Line Level 21 13th April 2009 05:10 PM
Jambo DAC - DIY USB/Optical/Coaxial DAC kit now available! Jambo Digital Source 8 20th August 2008 09:41 AM
Repairing Black Ash veneer BarakaBloke Multi-Way 22 2nd March 2008 05:39 PM
DPA little bit dac modding (7350 dac, ym3623b receiver) ash_dac Digital Source 16 5th December 2007 07:09 PM
FS: Unfinished ash baffles from my OB project - $25 - Seattle, WA area owdi Swap Meet 5 26th July 2007 08:54 PM
Copyright 1999-2017 diyAudio
